Results 1 to 6 of 6
    Full Member WERDNA's Avatar
    Structural
    WERDNA's Discipline Details
    Structural Designer
    Structural
    AutoCAD 2015
    Feb 2012
    Scotland
    85
    Default Delay on Pasting
    Hi All,
    Was wondering if any one could shed some light on why pasting details between drawings and blocks, the software or hardware, hangs for what seems to be an age, but is probably more like 10-15 seconds but over a day this is costly, any suggestions would be appreciated?
    Luminous Being RobDraw's Avatar
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    There are many possible causes. The first one that comes to mind is that there could be proxy objects or improperly converted files involved here. I see you are on AC LT 2007. Do you use .dwg files from outside sources? Are they saved down for your use? Sometimes the people at the other end don't realize that when saving down from AC Arch or MEP, they need to export rather than a simple save as to an older version.
    Drafting is a breeze.
    Structural
    Structural Designer
    Structural
    AutoCAD 2015
    Feb 2012
    Scotland
    85
    Hi Rob,
    Thanks for the response.
    There are details from solid edge files being used within the drgs, they are created in house and converted to Acad LT 2007.
    MEP 2017
    Apr 2007
    Connecticut, USA
    5,179
    You might want to look at the conversion process. I don't know anything about solid edge so I can't offer anything in that regard.
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,128
    Can you post your computer specs?
    Can you post a slow pasting object?
    What are the objects called (right-click>Properties)?
    Do you have all of the updates, hot fixes, Object Enablers, etc.?
  6. #6
    Structural
    Structural Designer
    Structural
    AutoCAD 2015
    Feb 2012
    Scotland
    85
    Spec attached, I am not sure about the updates etc but would say probably not.
    The problem has only recently begun, it is all objects, even as basic as copying a line there is a delay when pasting.
    Are the updates etc located on the Autodesk website?
  1. DELAY command
    By matrix in forum AutoCAD General
    Last Post: 10th Dec 2014, 11:32 am
  2. Delay in copying
    By ceeyespee in forum AutoCAD General
    Last Post: 30th Jun 2011, 02:52 pm
  3. command delay at 5 to 10 second
    By sachindkini in forum AutoCAD General
    Last Post: 29th Oct 2009, 07:49 am
  4. Copy Paste delay
    By Carl80 in forum AutoCAD General
    Last Post: 3rd Oct 2008, 01:40 am
  5. Delay when copying and pasting
    By Carl80 in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jun 2006, 08:44 am
