moniker Posted March 22, 2012 Share Posted March 22, 2012 I have a piece of my 3D model (it's a square tube with rounded corners) that I'm trying to display in a viewport in 2D but there are too many surface lines on the corners. Is there a way to display the rounded corners as sharp edges and the hidden lines of the object? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 22, 2012 Share Posted March 22, 2012 Is DISPSILH set to a value of "1"? Quote Link to comment Share on other sites More sharing options...
moniker Posted March 22, 2012 Author Share Posted March 22, 2012 No, it isn't. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 22, 2012 Share Posted March 22, 2012 Well give it a try and tell us if it solves the problem or not. Quote Link to comment Share on other sites More sharing options...
moniker Posted March 22, 2012 Author Share Posted March 22, 2012 I set the value to 1 and regenrated, but the 2D looks the same. Quote Link to comment Share on other sites More sharing options...
moniker Posted March 22, 2012 Author Share Posted March 22, 2012 Maybe this will help, on the left is how it appears and on the right is how I would like for it to appear. Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted March 22, 2012 Share Posted March 22, 2012 Try "Hidden visual style" Quote Link to comment Share on other sites More sharing options...
moniker Posted March 22, 2012 Author Share Posted March 22, 2012 Thanks, Mdb, I'll look into that. I just played with FLATSHOT and it seems to be doing what I want it to with the exception that all lines are continuous. If I can figure out how to make the hidden lines dashed, I'll be golden. Quote Link to comment Share on other sites More sharing options...
moniker Posted March 22, 2012 Author Share Posted March 22, 2012 So, I just tried "hidden" visual style, it gets rid of the surface lines on the exterior of the surface but it doesn't show any hidden lines. Any thoughts? Quote Link to comment Share on other sites More sharing options...
moniker Posted March 22, 2012 Author Share Posted March 22, 2012 I like the FLATSHOT command and I've found that if you explode the resulting block, the hidden lines become dashed as selected. But now the visible lines are defaulting the the "0" layer despite selecting "by layer" in the options. I suppose I can manually switch them all to the desired layer but if anyone has any insight into a less laborious method, please share. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted March 22, 2012 Share Posted March 22, 2012 _SECTIONPLANE or _SOLPROF or _SOLVIEW/_SOLDRAW, 2012 has _VIEWBASE. Quote Link to comment Share on other sites More sharing options...
rkent Posted March 22, 2012 Share Posted March 22, 2012 In a Layout use the new VIEWBASE command. Quote Link to comment Share on other sites More sharing options...
mdbdesign Posted March 23, 2012 Share Posted March 23, 2012 Change hidden lines in flatshot to hidden instead of byblock Quote Link to comment Share on other sites More sharing options...
Dadgad Posted March 24, 2012 Share Posted March 24, 2012 In a Layout use the new VIEWBASE command. When using the VIEWBASE command you can control the visibility of your HIDDEN and VISIBLE lines, each of which is further broken down into NARROW. You can set the linetypes and layer colors however you want them, and have other layer functionality available. If you want to lose the tangential visible lines, turn off VISIBLE NARROW. Or you can do the same with the HIDDEN NARROW lines, if the level of detail is too busy for your tastes. Remember that the VIEWBASE function is new to Autocad 2012, and in order for others using earlier versions of Autocad to be able to view them they will need to have downloaded (free from the Autodesk site) DWG Trueview 2012. Quote Link to comment Share on other sites More sharing options...
