Page 2 of 5 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 48
  1. #11
    Junior Member
    AutoCAD 2010
    Mar 2012
    19
    Thanks for the replies everyone. Problem still persists but its weird - I take the mouse to work, plug it into my work Dell laptop which runs AutoCAD 2010 and it pans and zooms with the wheel no problem.
    Then I bring it home, plug it into my home laptop (Dell again) running AutoCAD 2010 and the wheel is next to useless!
    So its not that its a cheap **** mouse! Its something else that I can't work out. Frustrating. I will keep looking at solutions.
  2. #12
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Check the value for your ZOOMFACTOR? Valid values are in the range of 3 to 100, with 100 being the highest value available.
  3. #13
    Junior Member
    AutoCAD 2010
    Mar 2012
    19
    Hi,
    Changing ZOOMFACTOR does nothing I'm afraid. Mousewheel still useless and I now had no idea how to get the damn thing panning and zooming. Why does it work when I plug it into my work laptop running the exact same AutoCAD version, but not on my home laptop??
    The work laptop is running Windows XP Pro whereas I run Windows 7 Pro which might be the cause. But how to rectify that?? No idea - will keep looking!
    Thanks
    Dave
  4. #14
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,125
    It is your mouse driver maybe. Are you using 32-bit or 64-bit OS? Did you try the program I recommended?
  5. #15
    Junior Member
    AutoCAD 2010
    Mar 2012
    19
    Hi SLW210,
    Thanks for the reply - yes, I tried the mouse tool re. the link you posted but there is no option for choosing AutoCAD as the application with which to tailor the mouse button/wheel clicks so it's of no help.
    I run Windows 7 Pro 64 Bit so I can only presume that's the problem here but when I try to download an updated mouse driver I get a message that the current driver is the most up to date and that everything is fine - which it is not!! Grrrrr
    So back to square one. Very frustrating but par for the course with IT......!!
  6. #16
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,125
    I use X Mouse Button Control just for AutoCAD, are you following the instructions? You just click Add and browse to the application file (ACAD.exe).
  7. #17
    Junior Member
    AutoCAD 2010
    Mar 2012
    19
    SLW210,
    Many thanks but, as ever with IT, its not straighforward it seems. I clicked 'add' to try to browse to 'ACAD.exe' but there is no such file located in any of the folders under the AutoCAD 2010 folder in the C;Programs directory. I can see nothing with that file extension but it must be somewhere!! I have unhidden
    So where is ACAD.exe located exactly so I can browse to it?? Sorry - not that up with this sort of stuff and its never as easy as it should be!
    Thanks loads,
    Dave
  8. #18
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 7 Home Premium (H)
    Lenovo ThinkStation D20 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Xeon E5503 (W)/AMD Athlon 2 X4 (H)
    4 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Quadro FX 580 (W)/nVidia GF GT430 (H)
    500 GB HDD (W)/1 TB (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Dell 22" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management
    AutoCAD 2012
    Sep 2002
    Winston-Salem, NC - USA
    4,455
    Hey David, did you ever check to see if your home laptop is running any 3rd party mouse software? I have seen this mess up AutoCAD before. I can almost bet that it is not Win7 doing this. I have a new Dell laptop running Win7 Home Prem 64-bit and my mouse works just fine. Honestly it should be plug and play. Did it ever work with this laptop? Have you tried another mouse just to eliminate a hardware problem? Sorry you are having just a time
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ - - http://cad-guy.tumblr.com/ -
  9. #19
    Junior Member
    AutoCAD 2010
    Mar 2012
    19
    Hi F700ES,
    Thanks for the post and your sympathies! This is doing my head I must admit. Yes it should be plug and play like everything else has been with my new Dell laptop and win 7 but not this issue. I tried plugging in a dell Mouse my wife uses which pans and zooms fine on her Acer machine when running the AutoCAD LT2008 vesion she has, but again, plug it into mine and - nothing.
  10. #20
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,125
    In AutoCAD commandline (findfile "acad.exe") should display the path.
  1. Zoom Using The Mouse Wheel
    By Mk1_Oz in forum AutoCAD Beginners' Area
    Last Post: 23rd Aug 2010, 02:17 am
  2. Mouse wheel won't zoom
    By Eatonpcat in forum AutoCAD General
    Last Post: 12th Jul 2010, 04:54 pm
  3. how to set wheel on mouse to zoom
    By raceredi in forum AutoCAD Beginners' Area
    Last Post: 25th Mar 2009, 08:23 pm
  4. Mouse wheel zoom
    By Tommo in forum AutoCAD Beginners' Area
    Last Post: 28th Mar 2006, 06:46 am
  5. Zoom in/out and pan with mouse wheel
    By Iris in forum AutoCAD Beginners' Area
    Last Post: 8th Feb 2006, 10:35 am
