blend [x]checked
the last step to model this work:
I would like to do the indentation of the red part in the image. it is a surface. every time I try to change it, it ends to a disaster. maybe i use the wrong tools.
Surface - Patch then Offset Surface with Solid=Yes
blend [x]checked
I would like to do the indentation of the red part in the image. it is a surface. every time I try to change it, it ends to a disaster. maybe i use the wrong tools.Attached Images
Try offset surface
I ve made a rod and after that: "arraypolar"
finally i used fillet edge.
it doesnt look as well as on the picture, but it's ok.
I am still working on the stripes... I m attempting to make a patch surface...
the result, after maya rendering:
by the way: i ve also controlled my edges with the analys tool, so I can see which one is alone. Consequently, you can avoid terrible rendering results...
