Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Forum Newbie
    AutoCAD 2012
    Mar 2012
    2
    Default Excel Database and AutCAD
    Good day,
    This is my first post after hours of searching. I have bits and pieces related to my question, but nothing substantial. I have a database with ~350 computer's physical coordinates within the building (actually not yet, but a field to fill) and all related info for that computer. Is it possible to have an object for each computer, and have that object's coordinates within the drawing updated when the database is updated? Or anything that can help with IT's management of these assets? The long-term goal is to have the maintenace people to be able to see where an asset(computer) is physically within the building. We will soon be using HP Service Manager 7 which utilizes a database with said information. I apologize if this is in the wrong thread. I have only fiddled with AutoCAD and am now jumping in head-first. I have only about 30 days to figure this out. Thanks!!! (patience with the Noob )
    Forum Newbie
    AutoCAD 2012
    Mar 2012
    2
    Ok. I found this from another site's forum....
    "You would need 2 VBA apps:
    1. From AutoCAD open and update Excel or a direct update of a csv file.
    2. From Excel open and update Autocad or use Open Design software.
    If it is just block refs this should be fairly easy if the block name is unique or you save the object handle in excel. WARNING: If a drawing has to be recovered the handle could change or the block name could change!!
    This is why my blocks have a Record Number Attribute that is unique for each block insertion."
    Sound correct? But I'm not that good at code(VBA).
    Super Member Murph_map's Avatar
    Murph_map's Computer Details
    XP,Visa, Win7
    HP something or other and the laptop is an HP too
    2 gigs or 6 gigs in Laptop
    Utilities
    Murph_map's Discipline Details
    Boats and campers renting and repairs
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    TN or KY depends if I'm at work or home.
    585
    Quote Originally Posted by Calen Anderson View Post
    I would forget about the VBA stuff it may not be around long. I also would not suggest Excel as it's not a database for records. Now either look at the DBConnect commands in AutoCAD or a good Facility Management application. I have done demos on what you are wanting but with AutoCAD MAP3D and databases.
    Murph
    Need a boat or camper for the weekend?
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    Maybe start by using Ms Acess which will convert your excell but has a look and fell like excel in simple mode then using Map3d you can do lots of enquiry stuff and have Autocad display.
  5. #5
    Junior Member
    AutoCAD 2010
    Apr 2012
    16
    i have link my excel spreadsheet to atuocad object, but my problem is that i cannot update my excel file from within autocad. the excel file is opened in
    READ ONLY mode in dbconnect data view window.how can i changed to edit mode
  6. #6
    XP,Visa, Win7
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    585
    In Excel yoiu need to save the file(s) spreadsheets as a shared file. Depending on what version of MS Office as to how, google it or check in the help for the correct way. Then reopen AutoCAD and make the connections.
    Murph
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    One can link a spreadsheet and a drawing via the DATALINK feature. This has been around since AutoCAD 2008.
  8. #8
    Junior Member
    AutoCAD 2010
    Apr 2012
    16
    Quote Originally Posted by Murph_map View Post
    i tried it but again the same thing i.e the excel spredsheet open in read only mode. i am using ms office 2010 64bit and autocad 2010 64bit. also i am using the DBCONNECT MANAGER to link my excel spreadsheet to my drawing object, for which i need to edit the excel table from within autocad.
  9. #9
    XP,Visa, Win7
    Utilities
    Utilities
    GIS and Map making.
    Map 3D 2011
    Feb 2011
    585
    Quote Originally Posted by tony barretto View Post
    When you use the ODBC Data Source Administrator make sure you check that read only is not checked.
    Murph
  10. #10
    Junior Member
    AutoCAD 2010
    Apr 2012
    16
    thanks for the jpg, but still i am unable to edit the excel data in autocad pls guide me further.
    thanks for ur help
  1. Shadow effects in AutCAD(dwg) file
    By ani_mit in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Jun 2008, 06:21 am
  2. autcad inline editor
    By geordieboy in forum AutoCAD Beginners' Area
    Last Post: 6th Oct 2006, 01:25 pm
  3. AutCAD crashing when rendering
    By gib65 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Sep 2006, 03:51 pm
  4. create a text database between excel and Autocad
    By cisrael in forum AutoCAD General
    Last Post: 30th Sep 2005, 10:08 pm
  5. AutCAD 2005
    By Scot C. Perry in forum AutoCAD General
    Last Post: 14th Jul 2005, 01:11 am
Tags for this Thread
