Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    Forum Newbie
    XxJAGERMASTERxX's Computer Details
    Windows 7 Professional 64bit
    LENOVO S20
    Intel Xeon W3550 x 2
    16 GB DDR3
    NVIDIA Quadro 2000
    LG FLATRON E2441
    HVAC
    XxJAGERMASTERxX's Discipline Details
    Draughtsman
    HVAC
    AutoCAD 2013
    May 2012
    New Zealand
    1
    I've been using autocad 2013 for the last week in the AutoCAD classic setting with only toolbars, so dont fret the toolbars are not disabled, i dont think they'll ever disable the toolbars being thats what everyone pre-2010 used and will be use to.
    Cheers,
  2. #12
    Super Member
    MisterJingles's Computer Details
    Windows 10 Pro 64bit
    Intel Core i7
    4.00GHz
    32GB
    GeForce GTX970
    Mechanical 2016
    Apr 2009
    South Africa
    533
    Quote Originally Posted by f700es View Post
    Honestly, you should really learn to use keyboard shortcuts instead of toolbars and ribbons. This will speed up your work and then it really won't matter what version you use. Sure you might have to change a few settings in the acad.pgp file (or the aliasedit command) when you start using a new version but once that is done you are set. I use the ribbon for seldom used commands and that is about it.
    I agree with you. Having recently switched companies I moved from Ribbons to Classic which was a big change and forced me to familiarize myself with shortcut commands and I work far quicker now. Having settled in I am moving back to Ribbons simply because I 'd like to keep current but like you I try use it only for seldom used commands.
    Don't forget your towel!
  1. "Hidden" line turns to "continuous" in layout view
    By jeck in forum AutoCAD General
    Last Post: 29th Mar 2015, 03:36 am
  2. How to change the look of Acad 2009 to "Classic.."
    By voltron in forum AutoCAD Beginners' Area
    Last Post: 17th Oct 2009, 04:02 am
  3. Line supression in "Hidden" view style
    By bacreman in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Jul 2009, 05:49 pm
  4. "Image" Menu into AutoCAD Classic
    By Vikes_Fl in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Apr 2009, 06:21 pm
  5. AutoCAD "CTAB" System Variable & DWG True View......
    By tzframpton in forum AutoCAD Drawing Management & Output
    Last Post: 26th Dec 2007, 03:33 pm
