Karltom Posted March 26, 2012 Share Posted March 26, 2012 Hi! I am new to Solidworks and normally works in ProE, but an subcontractor has done some models in Solidworks and the surface gets error when importing to ProE. So now I try to solve a problem in Solidworks and I do not get it to work. I have a complex body with many small surfaces and around this surface I would like to create a layer of 300 mm around the outside of the body. (It is pattern for moulding and I would like to calculate the volume of a 300 mm layer of moulding sand). I have tried the offset but that gets an errors and I have tried to scale up the body but since it is not completely filled the hole is also scaled up and give me an unknown faktor in my calculation. I have try to Knit the surface and then use the thicken or offset but that also giv me errors. Anyone have a good ide how to create the 300 mm layer around a body? /Tommy Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 27, 2012 Share Posted March 27, 2012 without seeing the body i can't tell you for sure BUT if you have an curvature to the body it will limit the offset distance. For instance if you had a cube with an external radius of 1mm. When you offset that radius 300mm you now have a 301mm radius. If this was an internal corner(or some curvature that is concave) it can only be offset until it no longer exists. That same example of a 1mm fillet can only approach a 1mm offset until that surface no longer exists. does this make sense? Im not sure i can be much more help without actually seeing some of the curvature. Quote Link to comment Share on other sites More sharing options...
Karltom Posted March 28, 2012 Author Share Posted March 28, 2012 Hi! I think that is the problem because I have surfaces with all types of curveture. See attach picture. I have done a small work around by using mold and scale I have been able to get an approx value for the 300 mm layer but there most be better way. Quote Link to comment Share on other sites More sharing options...
