jzookcaduser Posted March 27, 2012 Share Posted March 27, 2012 Hello, I'm really new to script files and I have a issue with about 250 drawings. The client had put the text on several different random layers and now wants the text all on one layer. I know I can select everything in the drawing, in the property pulldown, select text and switch layers. I would like to do this through a script file but I cant get past the properties drop down. Is there a way to select only text for changing through a script file? Thanks! Quote Link to comment Share on other sites More sharing options...
dbroada Posted March 27, 2012 Share Posted March 27, 2012 Its not easy (even possible) to use dialogue boxes with scripts. I was about to suggest that you use the action recorder but the more I look at it, the more I understand why people don't use it. So back to your problem. You can change an objects layer with a script using the CHANGE command. HOWEVER you still have to select all the text. This can be done with a simple SSGET lisp statement but I am not the person to show you what is required as I have forgotten. I am not aware of a way of making a selection from the command line which is what you require to use a script. FWIW, I would use QSELECT to select all the text and then use the properties but I think your way probably saves a few key strokes. Old habits die hard. Quote Link to comment Share on other sites More sharing options...
jzookcaduser Posted March 27, 2012 Author Share Posted March 27, 2012 Dave, Thanks for the info, it was helpful and gave me a good jumping off point. The dialogue box was in the way and I was just trying to by-pass it perhaps I will try the action recorder just to see what happens. Thanks again. John Quote Link to comment Share on other sites More sharing options...
