Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2012
    Mar 2012
    3
    Default Absolute coordinates
    kindly help mo on this..using absolute coordinates:
    1. L enter
    2. 10,10 enter ( i've got the starting point with this coordinate, which is correct)
    3. 60,10 enter ( when i enter this coordinates, instead of having a straight line starting from point 10,10...i've got a slanting line and not a straight line from 10,10 going to distance 60)...
    kindly enlighted me...take consideration on absolute coordinates NOT relative Cartesian Coordinates...thanks
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,108
    Probably the same UCS problem that is making your circles look like ellipses.
    Can you post some screen shots or the drawing?
    AARi
    (1)line 10,10
    (2)@60,10 << so you get a slating line
    @ means end point from last input point value (relative coords.)
    check setting... seems something wrong
    Senior Member welldriller's Avatar
    welldriller's Computer Details
    Windows 10 Home
    Dell inspiration 3650
    x64 processor
    8 GB
    Dell P190SB#4
    Solidworks 2017
    Jan 2013
    Federalsburg, Maryland
    312
    Set osnap on
    Choose Line
    Choose end of line you want to continue with
    On the command line -- try typing @60<0 -- then enter
    This should give you a straight horizontal line
  1. Arc (start-2nd-end point) absolute or relative coordinates
    By khoshravan in forum AutoCAD General
    Last Post: 5th Sep 2011, 07:22 am
  2. get absolute coordinates of a block reference
    By Dill in forum AutoCAD Beginners' Area
    Last Post: 26th Jul 2010, 10:13 am
  3. absolute x and absolute y values
    By Niles in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jun 2010, 03:49 am
  4. Absolute and relative CS
    By przemek2727 in forum AutoCAD Beginners' Area
    Last Post: 31st Dec 2008, 05:40 pm
  5. Absolute Newbie
    By VinUk in forum AutoCAD Beginners' Area
    Last Post: 20th Oct 2004, 06:25 pm
