Results 1 to 7 of 7
    Full Member
    not specified
    Apr 2006
    Bogota, Colombia
    63
    Default XYZ coordinate data export
    How do I export the XYZ coordinate data of 3D polyline vertices into a *txt or *xls files?
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    You will need a Lisp routine. Do you have the full AutoCAD?
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Full Member
    not specified
    Apr 2006
    Bogota, Colombia
    63
    Yes, I do have the full of AutoCAD 2007. Do you know where I can find such a routine? Thanks for the reply
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Try PTEXPORT.LSP, found at http://www.dotsoft.com/freestuff.htm
  5. #5
    Senior Member
    AutoCAD 2008
    Nov 2005
    Bulgaria, Sofia
    228
    You can try the following VBA application. It displays the coordinates of all 3DPolylines selected by the user in Excel.
    Sub Export3DPolylines()
    Dim objSS As AcadSelectionSet
    On Error Resume Next
    ThisDrawing.SelectionSets("MySS").Delete
    ThisDrawing.SelectionSets.Add ("MySS")
    Set objSS = ThisDrawing.SelectionSets("MySS")
    objSS.SelectOnScreen
    Dim objent As AcadEntity
    Dim MasRem() As AcadEntity
    Dim N As Integer
    N = -1
    For Each objent In objSS
    If objent.ObjectName <> "AcDb3dPolyline" Then
    N = N + 1
    If N = 0 Then
    ReDim MasRem(N)
    Else
    ReDim Preserve MasRem(N)
    End If
    Set MasRem(N) = objent
    End If
    Next
    objSS.RemoveItems MasRem
    If objSS.Count = 0 Then
    MsgBox "No 3DPolylines found!"
    Exit Sub
    End If
    Dim Excel As Object
    Set Excel = CreateObject("Excel.Application")
    Set wkb = Excel.workbooks.Add
    Set sht = wkb.sheets(1)
    Dim MasCoord As Variant
    Dim Col As Integer
    Dim Row As Integer
    Col = -3
    Row = 1
    For i = 0 To objSS.Count - 1
    Col = Col + 4
    Row = 1
    MasCoord = objSS(i).Coordinates
    sht.cells(1, Col) = "3DPolyline " & i + 1 & " coordinates"
    sht.cells(2, Col) = "X"
    sht.cells(2, Col + 1) = "Y"
    sht.cells(2, Col + 2) = "Z"
    Row = 2
    For j = 0 To (UBound(MasCoord) + 1) / 3 - 1
    Row = Row + 1
    sht.cells(Row, Col) = MasCoord(3 * j)
    sht.cells(Row, Col + 1) = MasCoord(3 * j + 1)
    sht.cells(Row, Col + 2) = MasCoord(3 * j + 2)
    Next
    Next
    Excel.Visible = True
    End Sub
  6. #6
    AutoCAD 2006
    Nov 2002
    3,540
    and this is for exporting polyline points into text or csv files to open them in excel. Note thet you can edit the program text tochange the separator. You may use \t to have the items separated by a tab, \n to have them on a new line or use any other symbol.
    Code:
    ;export old style polyline vertex coords to a text file
    ;	mfuccaro@hotmail.com
    &#40;defun c&#58;pl2tx&#40; / en ask i a file&#41;
      &#40;while &#40;not ask&#41;
        &#40;setq en &#40;car &#40;entsel&#41;&#41;&#41;
        &#40;if en &#40;setq ask &#40;= "POLYLINE" &#40;cdr &#40;assoc 0 &#40;entget en&#41;&#41;&#41;&#41;&#41;&#41;
        &#41;
      &#40;setq file &#40;open &#40;getfiled "Output file"
    			     &#40;strcat &#40;getvar "dwgprefix"&#41;
    			     &#40;substr &#40;getvar "DWGNAME"&#41; 1 &#40;- &#40;strlen &#40;getvar "dwgname"&#41;&#41; 4&#41;&#41;&#41;
    			     "txt"     ;file type
    			     1&#41; "w"&#41;&#41;
      &#40;setq i 0 sep ";"&#41;	;sep=separator
      &#40;while &#40;or &#40;zerop i&#41; a&#41;
        &#40;setq a &#40;mapcar 'rtos &#40;cdr &#40;assoc 10 &#40;entget &#40;setq en &#40;entnext en&#41;&#41;&#41;&#41;&#41;&#41;&#41;
        &#40;if a &#40;write-line &#40;strcat &#40;car a&#41; sep &#40;cadr a&#41; sep &#40;caddr a&#41;&#41; file&#41;&#41;
        &#40;setq i &#40;1+ i&#41;&#41;
        &#41;
      &#40;close file&#41;
      &#40;princ &#40;strcat "\n" &#40;itoa &#40;1- i&#41;&#41; " points exported"&#41;&#41;
      &#40;princ&#41;
      &#41;
    And HERE you will find help on how to run Lisp routines.
  7. #7
    Forum Newbie
    AutoCAD 2008
    Apr 2010
    1
    Hey... a few years later I found this post.
    I ran the vba from Joro thanks it works really good except that...
    Id really like to have alle the coordinate in the first 3 row. The code does export the coordinate of each polyline in different set of 3 row.
    I tried to modified the code with no sucess. I tried to change col = col +4 to col = col but it didnt work.
    I no nothing about coding.
    If someonw can help it will save me a lot of time.
    Thanks
