Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    Senior Member resullins's Avatar
    resullins's Computer Details
    XP... moving to 7 soon, hopefully.
    Dell Precision T4500
    Intel Xeon E5405
    4.00 GB
    NVidia Quadro NVS 290
    Dual Dell 20" 16x9 running DVI-D
    AutoCAD 2012
    Feb 2011
    Nashville, TN
    403
    Default Keyboard Shortcut for LISP command
    I have a LISP command, ARRAYINCREMENT.lsp, with an alias of IA. However, I need to assign a keyboard shortcut to it (i.e. CTRL+G) so that I can put it on a certain button of my mouse. However, it doesn't appear in my list of all commands in my CUI, so I'm not sure how to get to it to assign it.
    Any ideas? I'm really trying to get faster, and the little buttons on my mouse are SO handy for that!
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Can't you create a command in the CUI with a macro assigned to it that calls the Lisp?
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,945
    I know that newer versions have pretty much locked out use of Ctrl key - One work around for this is to use CUI Editor, Transfer Tab, and drag an existing Shortcut Key (Keyboard Shortcuts, Shortcut Keys node) into a separate CUI(x) file. Set that CUI(x) as Main, and edit as needed. When done, restore original Main CUI(x) and use Transfer Tab to drag to Main CUI(x).
    Note that you may be overwriting an existing shortcut, depending on your naming convention, command, etc., and that the 'Element ID' (from the original shortcut) will remain.
    I only have one legacy shortcut key, given that my mouse, keyboard accept (multiple key) Macros, so I just use that instead. There may be a better way to accomplish what I described above.
    HTH
    "Potential has a shelf life." - Margaret Atwood
    Intel Xeon E5405
    4.00 GB
    AutoCAD 2012
    Feb 2011
    Nashville, TN
    403
    Hmmm.... @Tiger: I don't know how to create a custom command in the CUI.
    @Render: I have unassigned the shortcut keys I don't use. Like CTRL+L... since I never use Ortho, and reassigned them to the commands I want to put on my mouse. Copy, Matchprop, etc.
    Now, I'm not sure what you're trying to tell me about the custom CUI. I already use a custom CUI...
  5. #5
    Civil 3D 2011
    Nov 2009
    3,945
    Quote Originally Posted by resullins View Post
    Simple - from CUI Editor, bottom left pane, make sure 'Command List' is expanded, then select the 'Create new command' button (the star with asterisk in upper right).
    Unassign =/= Assign ... This just disables the existing shortcut, and does not enable your customized version.
    If a Temporary Override is insufficient, then you have to bring a Shortcut Key into your Main CUI(x) by way of the Transfer Tab, from which you can customize as needed.
  6. #6
    Super Member mdbdesign's Avatar
    mdbdesign's Computer Details
    XP PRO
    Homemade
    GIGABYTE G31M-ES2L
    INTEL CORE 2-QUAD-Q6600@2.4GHz
    4 GB
    NVIDIA GeForce 9800 gt 1gb
    WESTERN DIGITAL 500GB
    2 - 21" COMPACQ
    Mechanical
    mdbdesign's Discipline Details
    Designing Engineer in Engineering Department
    Mechanical
    Pressure tanks Oil processing & storage equip. Steel mill equip. Telecom towers & equip. Wind turbine towers Power plant structures etc.
    AutoCAD 2012
    Jan 2007
    Courtice, Ontario, Canada
    749
    What I do is:
    Add lisp to Startup suite
    Type IA ( in my Autocad "IA" is not used for anythig) and that it.
    Try it.
    Marek
  7. #7
    Civil 3D 2011
    Nov 2009
    3,945
    Consider the original post:
    Quote Originally Posted by mdbdesign View Post
    What I do is:
    Try it.
  8. #8
    XP PRO
    Homemade
    GIGABYTE G31M-ES2L
    4 GB
    2 - 21" COMPACQ
    Mechanical
    Mechanical
    AutoCAD 2012
    Jan 2007
    749
    Quote Originally Posted by RenderMan View Post
    My bad, sorry.
    Marek
  9. #9
    Civil 3D 2011
    Nov 2009
    3,945
    My bad, sorry.
    No worries, mate... I do the same thing from time to time.
  10. #10
    Intel Xeon E5405
    4.00 GB
    AutoCAD 2012
    Feb 2011
    Nashville, TN
    403
    Got it! Thanks!
  1. Keyboard shortcut woes
    By ColinPearson in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Nov 2010, 04:57 pm
  2. Filter to keyboard shortcut
    By Butch in forum AutoCAD Beginners' Area
    Last Post: 18th Mar 2010, 09:10 pm
  3. My keyboard shortcut is MIA
    By BOB'27T in forum AutoCAD Drawing Management & Output
    Last Post: 31st Oct 2007, 11:35 am
  4. Tutorial: Create a command alias (keyboard shortcut)
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 18th Mar 2007, 12:11 am
  5. Shortcut keyboard
    By Ducati in forum AutoCAD Beginners' Area
    Last Post: 21st Jun 2005, 06:17 am
