M2P (mid between two points) and select the end points of the wall.
I used to be able to snap to the midpoint of my wall when it had doors/windows in it. Now it snaps to the midpoint between the end of my door/window & the endpoint of my wall. I do not want to snap to the "new" midpoint, I want the midpoint of the entire wall. anyone know how to fix this problem?
I never had to use M2P prior to this, and I did not switch versions either. all of a sudden it's like my autocad has taken on all new properties.
Has your user profile been changed?
Volume and repetition do not validate opinions forged in the absence of thought.
Sounds like you are now breaking the wall where you insert the windows/doors.
I would say that would be an Architecture problem if they are wall objects.
