Goomba Posted March 29, 2012 Share Posted March 29, 2012 I swear in Solidworks 2011 I could drop down on the dimension box and click add equation and then click on another dimension in the sketch and create an equation using it? Now it is no longer there.. I can type "D1@Sketch1" / 2 which will create a simple equation but it doesnt remain as an equation it just changes the value to the answer of the equation, if I change the dimension referenced this one doesnt update. Same thing happens if I try to do it in the Equation box. Is there something I need to turn on to get equations to actually be equations and not calculators?! Thanks in advance Quote Link to comment Share on other sites More sharing options...
fuccaro Posted March 29, 2012 Share Posted March 29, 2012 Try starting the equation with the equal sign (=). I am new too to SW so I could be wrong. Sorry, I can't test the solution right now. Quote Link to comment Share on other sites More sharing options...
Goomba Posted March 29, 2012 Author Share Posted March 29, 2012 That works! Thanks! I am sure it was like a drop down in the dimension window where you had to choose equation before, and then could click on the dimension you wanted to use rather than type it out. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted March 29, 2012 Share Posted March 29, 2012 Something like this? (The dimension I'm editing is hidden behind the dialog box.) Quote Link to comment Share on other sites More sharing options...
Goomba Posted March 30, 2012 Author Share Posted March 30, 2012 Yes JD like that! See below screenshot of what I am seeing, notice no drop down like where you have the green arrow pointing to in your example. Quote Link to comment Share on other sites More sharing options...
SuperCAD Posted March 30, 2012 Share Posted March 30, 2012 You don't have to type it out. Just put the = sign in and click on the dimension you want to use. You can write your equations right in the text box and use any dimensions you want as long as they are visible. Quote Link to comment Share on other sites More sharing options...
Goomba Posted March 30, 2012 Author Share Posted March 30, 2012 Thank you! That is pretty much as easy as I wanted it to be. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted March 30, 2012 Share Posted March 30, 2012 2012 saw a big change in the equation and editor so it does act a little different but i think you got it. here is a video that might help. http://www.mymlcservices.com/index.php?option=com_hwdvideoshare&task=viewvideo&video_id=394&Itemid=611 Quote Link to comment Share on other sites More sharing options...
