Results 1 to 3 of 3
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,233
    Default Duplicate Mark Warning
    I have to modify hundreds of VAV tags and I am getting this warning for each one. Is there a way to turn off that warning temporarily turn off all warnings?
    Rob
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,233
    This actually turned out to be a lot less annoying than it was when I first started. If you edit the tag, (which is reading the mark value), at the tag as opposed to using the properties box to edit the mark value, the warning box closes itself when you continue doing you work. If you do it through the properties box, you have to close it manually.
    Rob
    Senior Member Lee Roy's Avatar
    Lee Roy's Computer Details
    Windows 7 Professional 64-bit
    HP Z400
    Intel Xeon W 3565 @ 3.2GHz
    16GB
    ATI FirePro V5900
    OCZ Vertex 4 - 256GB - Sata III - SSD
    Seagate Barracuda 1TB 7200rpm
    Dual - HP Compaq LA2405wg
    Multi-disciplinary
    Lee Roy's Discipline Details
    CAD/BIM Manager
    Multi-disciplinary
    Architectural, Mechanical, Plumbing, Electrical...JOAT
    Revit 2014
    Apr 2011
    Visalia, CA
    417
    Custom field in the VAV family with a custom tag, was my cure. Then I don't care what the Mark Value is, cause I'm not using it.
    "The thing about quotes on the internet is that you cannot confirm their validity." - Abraham Lincoln
    I -edit- a lot, sorry.
    The rotary engine is the most efficient way of converting fuel to noise ever invented.
    If my post sounds offensive, but can be meant in a non-offensive manner...I meant the latter.
  1. Center Mark Style - Help
    By john7911 in forum Autodesk Inventor
    Last Post: 17th Jul 2011, 05:59 pm
  2. Center Mark in 2010
    By ziemerd in forum AutoCAD Beginners' Area
    Last Post: 2nd Jun 2010, 02:35 pm
  3. big red X mark on my layer properties
    By iskalipsi in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th May 2010, 09:37 am
  4. Please check! i need to add foot mark '
    By ascen707 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2007, 01:12 pm
  5. how to mark using arrows?
    By orceller in forum AutoCAD Beginners' Area
    Last Post: 12th Mar 2007, 10:04 am
