Results 1 to 6 of 6
    Junior Member
    3ds Max Design 2010
    Jun 2010
    12
    Default Coordinate Points Problem...
    Hi guys..i'm new in max. I have basic question and sorry with my english, hope i can
    explain it clear enough.
    Sometimes before making any model, i use assist lines to give better result.
    Then i can start modeling using any primitives.
    But why everytime i try to place primitives object's coordinates onto assist lines,
    they always placed up differently although each points are already at the same number?
    I can always see that problem with 3-5 zooms
    Is anyone can help me please?
    Thanks
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,297
    Sorry but I'm not sure I understand the question?
    Can you post some screenshots to help illustrate the problem you're having?
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
    Junior Member
    3ds Max Design 2010
    Jun 2010
    12
    Ok I think i'll just use simple spline to make it easier to me to explain..
    Maybe this will look stupid
    I created line in here and dragged its pivot to the left edge. Then i cloned another one and rotated 45'.
    Next i moved it to the first line edge using snap toggle.
    See what happen with the pivot. Already the same x,y,z coordinate number but still end up in different place.
    And basicly this my problem is....
    Any help please....?
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    Southern California
    10,297
    Ok, if I understand correctly, you are saying the endpoints of the lines are at the same coordinate location but the pivots are at different locations, correct?
    You should not confuse the pivot location and the endpoint location. They are two totally different things. The endpoint locations are absolute. When you snap two lines or objects together by their endpoints, they will be precise and correct, but you can move the pivots anywhere you want. So don't worry about where the pivot is, in relation to the endpoint, it's not really important. Unless you need it to be right at the endpoint for some reason.
    Facebook:
  5. #5
    Junior Member
    3ds Max Design 2010
    Jun 2010
    12
    In my case, i do need each of these red line edges gizmos to remain where they are (Pic A), so i can either rotate and move'em when needed.
    Moreover to make the plane vertex snapped into every line edges perfectly (ex: Pic B). I just don't get it, somehow they always end up like this (Pic C and C01). This will cost me a hard time when snap something to it, rotate etc.
    I might still be able to just snap'em the way they are and keep move on (Pic D)...but unless this is the only way that max has,
    i'll still wondering if there's better way to do it right...
  6. #6
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2014
    Feb 2006
    Southern California
    10,297
    I think you're getting too caught up in where the pivot point is in relation to the object. It doesn't really matter unless you've absolutely got to have it right at the endpoint. If that is in fact the case, then just move the pivot to the endpoint.
    1. Activate your Snaps Toggle
    2. Open the Grid and Snap Settings
    3. Set "Pivot" and "Endpoint" active
    4. Go to the "Hierarchy" panel
    5. Select "Affect Pivot Only"
    6. Choose "Select and Move"
    7. Move your cursor to the center of the Gizmo until you see a small circle appear at the intersection of all 3 axis
    8. Click and drag the Gizmo over to the endpoint until it snaps in place
    Facebook:
  1. Problem with the Coordinate Conversion
    By username85 in forum Map 3D
    Last Post: 27th Oct 2014, 10:10 am
  2. MapGuide Author 6.5 coordinate system problem
    By ariel123 in forum Autodesk Software General
    Last Post: 7th Jul 2010, 07:37 am
  3. Coordinate Display problem
    By binkerdunc in forum AutoCAD Beginners' Area
    Last Post: 4th Jul 2009, 01:26 pm
  4. Replies: 2
    Last Post: 27th Apr 2007, 08:54 am
  5. screensize/coordinate problem
    By nico in forum AutoCAD Drawing Management & Output
    Last Post: 8th Nov 2005, 11:28 am
