Results 1 to 5 of 5
    Senior Member
    MEP 2011
    Jun 2007
    194
    Default Content Builder question!!
    I have downloaded some 3d drawings off Spirax website, ( Steam Separator,...)
    I can easily used MVPARTCONVERT and convert them to MEP parts.
    But, when I use Content builder, everything is fine till I click on Edit Placemnet, then I can't see the parts. for some reason they disappear from the drawing.
    Could this be, because the parts are not true solid models???
    Thanks
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,497
    This is very common. The best practice I use is to start a very fresh Template, not an MEP Template, a vanilla AutoCAD Template, then copy/paste as close to the origin as possible. Basically, use the "bottom left corner" of the 3D solid as your 0,0,0. Try that and then start building the part. See if this yields better results.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Senior Member
    MEP 2011
    Jun 2007
    194
    Thanks for help and sorry for late reply
    It worked for some of the parts.
    Thanks again for your help.
    Can someone upload a project done in MEP so I can explorer and get ideas from. Prefer something that contains various different piping systems.
    Thanks
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,497
    I had a HUGE $15 million mechanical piping project that I recently did but I don't have access to the AutoCAD MEP files anymore. That had literally everything in it, for a food processing plant. Great file to explore, but unfortunately I don't have the files anymore. I might, let me do some digging but I doubt it.
    I do have a good HVAC project available for download if interested in Mechanical HVAC design using AutoCAD MEP.
  5. #5
    Senior Member
    MEP 2011
    Jun 2007
    194
    Thanks a lot StykFacE
    You have been a big help.
    Anything would be helpful, if it’s not much trouble for you.
    Looking forward to seeing your work and learn from you.
  1. Merging Content Builder files
    By NH3man! in forum MEP
    Last Post: 9th Dec 2011, 02:47 am
  2. Replies: 1
    Last Post: 15th Apr 2011, 06:46 am
  3. Parametric content builder. Fittings
    By cdholder in forum MEP
    Last Post: 3rd Sep 2010, 08:02 am
  4. MEP Content Builder
    By dsibbo in forum MEP
    Last Post: 5th Nov 2008, 05:55 pm
  5. Content center question
    By abstracted in forum Autodesk Inventor
    Last Post: 22nd Oct 2008, 04:01 pm
