+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Senior Member
    Computer Details
    hoss's Computer Details
    Operating System:
    Windows 7 - 64 Bit
    Computer:
    Dell Precision T1600
    Using
    MEP 2012
    Join Date
    Jun 2007
    Location
    South Yorkshire, UK
    Posts
    236
    Default Content Builder question!!
    I have downloaded some 3d drawings off Spirax website, ( Steam Separator,...)
    I can easily used MVPARTCONVERT and convert them to MEP parts.
    But, when I use Content builder, everything is fine till I click on Edit Placemnet, then I can't see the parts. for some reason they disappear from the drawing.
    Could this be, because the parts are not true solid models???
    Thanks
  2. #2
    Luminous Being tzframpton's Avatar
    Computer Details
    tzframpton's Computer Details
    Computer:
    HP Zbook
    Discipline
    Multi-disciplinary
    tzframpton's Discipline Details
    Occupation
    BIM Specialist
    Discipline
    Multi-disciplinary
    Details
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Using
    Revit 2019
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    9,117
    Default
    This is very common. The best practice I use is to start a very fresh Template, not an MEP Template, a vanilla AutoCAD Template, then copy/paste as close to the origin as possible. Basically, use the "bottom left corner" of the 3D solid as your 0,0,0. Try that and then start building the part. See if this yields better results.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  3. #3
    Senior Member
    Computer Details
    Operating System:
    Windows 7 - 64 Bit
    Computer:
    Using
    MEP 2012
    Join Date
    Jun 2007
    Location
    South Yorkshire, UK
    Posts
    236
    Default
    Thanks for help and sorry for late reply
    It worked for some of the parts.
    Thanks again for your help.
    Can someone upload a project done in MEP so I can explorer and get ideas from. Prefer something that contains various different piping systems.
    Thanks
  4. #4
    Computer Details
    Computer:
    HP Zbook
    Discipline
    Multi-disciplinary
    Occupation
    BIM Specialist
    Discipline
    Multi-disciplinary
    Details
    Using
    Revit 2019
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    9,117
    Default
    I had a HUGE $15 million mechanical piping project that I recently did but I don't have access to the AutoCAD MEP files anymore. That had literally everything in it, for a food processing plant. Great file to explore, but unfortunately I don't have the files anymore. I might, let me do some digging but I doubt it.
    I do have a good HVAC project available for download if interested in Mechanical HVAC design using AutoCAD MEP.
  5. #5
    Senior Member
    Computer Details
    Operating System:
    Windows 7 - 64 Bit
    Computer:
    Using
    MEP 2012
    Join Date
    Jun 2007
    Location
    South Yorkshire, UK
    Posts
    236
    Default
    Thanks a lot StykFacE
    You have been a big help.
    Anything would be helpful, if it’s not much trouble for you.
    Looking forward to seeing your work and learn from you.
Similar Threads
  1. Merging Content Builder files
    By NH3man! in forum MEP
    Last Post: 9th Dec 2011, 02:47 am
  2. Replies: 1
    Last Post: 15th Apr 2011, 06:46 am
  3. Parametric content builder. Fittings
    By cdholder in forum MEP
    Last Post: 3rd Sep 2010, 08:02 am
  4. MEP Content Builder
    By dsibbo in forum MEP
    Last Post: 5th Nov 2008, 05:55 pm
  5. Content center question
    By abstracted in forum Autodesk Inventor
    Last Post: 22nd Oct 2008, 04:01 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
