Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Diemaker Users?
    Forum Newbie
    Deepdraw's Computer Details
    Windows 7
    Manufacture
    Deepdraw's Discipline Details
    Metal Stamping
    Manufacture
    AutoCAD 2010
    Mar 2012
    Rockford, IL. USA
    5
    Default Diemaker Users?
    Any Diemaker users on Cadtutor? All of the engineers here at Rockford Toolcraft Inc use AutoCAD 2010 and Diemaker 2010 works within it. AutoCAD is used specifically to design our heavy gauge stamping dies. After some recent upgrades to Windows 7 64bit PCs, Diemaker refuses to install correctly on two of them. There is no error message, it simply does not show up within AutoCAD. There is usually a toolbar. It runs perfectly on the others. All of the PCs are alike. Helpful ideas would be greatly appreciated.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,021
    Some programs refuse, for whatever reason, to install under Win7 64-bit. Have you contacted Diemaker support to inquire about the problem?
    Forum Newbie
    Windows 7
    Manufacture
    Metal Stamping
    Manufacture
    AutoCAD 2010
    Mar 2012
    Rockford, IL. USA
    5
    Thank you for your reply. Yea, it's seems hit and miss. It just refuses to install on two, but the rest it works perfectly. Yes, the support guru has been in a couple of times and with no luck.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,021
    It shouldn't be. Do all the computers share the same configuration? If not, what are the differences?
  5. #5
    Forum Newbie
    Windows 7
    Manufacture
    Metal Stamping
    Manufacture
    AutoCAD 2010
    Mar 2012
    Rockford, IL. USA
    5
    Yes, they are all the same configuration. No differences whatsoever.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,021
    Did IT try disabling the antivirus program during the install process?
    When the install did not work were there any error messages?
  7. #7
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    I would go to one of the machines where the install worked, open AutoCAD, go to Options, Files, Support File Search Path, make a copy of all the paths there. Then go to one where it won't open and compare the file path to the good machine. If something is missing add it into the one missing it. Open a drawing and try again.
    I would also start AutoCAD making sure to use a new profile and maybe do that while logged in as Admin to eliminate any problems with profiles as a cause.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  8. #8
    Forum Newbie
    Windows 7
    Manufacture
    Metal Stamping
    Manufacture
    AutoCAD 2010
    Mar 2012
    Rockford, IL. USA
    5
    Yes, anitivirus was uninstalled prior to the Diemaker install. There was no error message. Thanks again.
  9. #9
    Forum Newbie
    Windows 7
    Manufacture
    Metal Stamping
    Manufacture
    AutoCAD 2010
    Mar 2012
    Rockford, IL. USA
    5
    Quote Originally Posted by rkent View Post
    Just looked into this. The folders match and both show the software is there. The software does run as local Administrator, but refuses to run as an Administrator on the domain. Again, only two PCs do this, the others run perfectly on the domain.
    Thank you for the insight.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,021
    Ah...another piece of the puzzle has been provided.
  1. Too many users
    By Coosbaylumber in forum AutoCAD General
    Last Post: 3rd Sep 2010, 04:29 pm
  2. CutePDF Pro users...
    By nscherneck in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jul 2007, 05:25 am
  3. Inventor Users
    By FIFTHTEXAS in forum Autodesk Inventor
    Last Post: 10th May 2007, 05:03 pm
