So, my coworkers like Terry Miller's T2M.lsp, they prefer using his lisp to Express tool's Text to Mtext. I've taken a look at it, but at my current skill level much of his code is above my head. Their only complaint is that if a text is rotated when they use this command, it rotates the text on them again. Somewhat irritating.
I've looked through it, and I can't understand why he runs a "Rotate" command inside the lisp when he could simply tell entmake to put the original angle into the 50 code line...
Can anyone else understand this and help me "fix" this so my coworkers can use this without their text being flipped?
Code:;------------------------------------------------------------------------------- ; Program Name: T2M - Text to Mtext ; Created By: Terry Miller (Email: terrycadd@yahoo.com) ; (URL: http://web2.airmail.net/terrycad) ; Date Created: 7-17-08 ; Function: Changes Text to Mtext ;------------------------------------------------------------------------------- ; Revision History ; Rev By Date Description ;------------------------------------------------------------------------------- ; 1 TM 7-17-08 Initial version ;------------------------------------------------------------------------------- ; c:T2M - Text 2 Mtext ;------------------------------------------------------------------------------- (defun c:T2M (/ Angle~ Cnt# Color# Dxf10 Dxf11 Dxf72 Dxf73 EntList@ EntName^ InsPt Justify# Layer$ MTextPts@ Osmode# P1 P2 SS& Text$ TextPts@ TextSize~ TextStyle$ Width~) (princ "\nSelect Text to change to Mtext.") (if (setq SS& (ssget (list '(0 . "TEXT")))) (progn (command "UNDO" "BEGIN") (setq Osmode# (getvar "OSMODE")) (setvar "OSMODE" 0) (setvar "CMDECHO" 0) (setq Cnt# 0) (repeat (sslength SS&) (setq EntName^ (ssname SS& Cnt#)) (setq EntList@ (entget EntName^)) (setq Text$ (cdr (assoc 1 EntList@))) (setq TextStyle$ (cdr (assoc 7 EntList@))) (setq Layer$ (cdr (assoc 8 EntList@))) (setq Dxf10 (cdr (assoc 10 EntList@))) (setq Dxf11 (cdr (assoc 11 EntList@))) (setq TextSize~ (cdr (assoc 40 EntList@))) (setq Angle~ (cdr (assoc 50 EntList@))) (setq Color# (cdr (assoc 62 EntList@))) (setq Dxf72 (cdr (assoc 72 EntList@))) (setq Dxf73 (cdr (assoc 73 EntList@))) (setq Justify# (cond ((and (= Dxf72 0)(= Dxf73 3)) 1);TL ((and (= Dxf72 1)(= Dxf73 3)) 2);TC ((and (= Dxf72 2)(= Dxf73 3)) 3);TR ((and (= Dxf72 0)(= Dxf73 2)) 4);ML ((and (= Dxf72 1)(= Dxf73 2)) 5);MC ((and (= Dxf72 2)(= Dxf73 2)) 6);MR ((and (= Dxf72 0)(= Dxf73 1)) 7);BL ((and (= Dxf72 1)(= Dxf73 1)) 8);BC ((and (= Dxf72 2)(= Dxf73 1)) 9);BR ((and (= Dxf72 4)(= Dxf73 4)) 5);MC ((and (= Dxf72 1)(= Dxf73 0)) 8);BC ((and (= Dxf72 2)(= Dxf73 0)) 9);BR (t 7);BL );cond );setq (if (= Justify# 7) (setq InsPt Dxf10) (setq InsPt Dxf11) );if (setq TextPts@ (Text-Box EntName^)) (setq Width~ (distance (nth 0 TextPts@) (nth 1 TextPts@))) (setq P1 (polar (nth 0 TextPts@) (angle (nth 0 TextPts@) (nth 2 TextPts@)) (/ (distance (nth 0 TextPts@) (nth 2 TextPts@)) 2.0)) );setq (command "ERASE" EntName^ "") (entmake (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(67 . 0) (cons 410 (getvar "CTAB"));Layout name (cons 8 Layer$);Layer name '(100 . "AcDbMText") (cons 10 InsPt);Insertion (cons 40 TextSize~);Text size '(41 . 0.0) (cons 71 Justify#);Justification '(72 . 5) (cons 1 Text$);Text value (cons 7 TextStyle$);Text style '(210 0.0 0.0 1.0) '(11 1.0 0.0 0.0) (cons 42 Width~);Textbox width (cons 43 TextSize~);Text size '(50 . 0.0) '(73 . 1) '(44 . 1.0) ));list;entmake (if Color# (command "CHPROP" (entlast) "" "C" Color# "") );if (command "ROTATE" (entlast) "" InsPt (rtd Angle~)) (setq MTextPts@ (Text-Box (entlast))) (setq P2 (polar (nth 0 MTextPts@) (angle (nth 0 MTextPts@) (nth 2 MTextPts@)) (/ (distance (nth 0 MTextPts@) (nth 2 MTextPts@)) 2.0)) );setq (command "MOVE" (entlast) "" P2 P1) (setq Cnt# (1+ Cnt#)) );repeat (setvar "OSMODE" Osmode#) (command "UNDO" "END") );progn );if (princ) );defun c:T2M ;------------------------------------------------------------------------------- ; rtd - Radians to degrees ;------------------------------------------------------------------------------- (defun rtd (Rad~) (* 180.0 (/ Rad~ pi)) );defun rtd ;------------------------------------------------------------------------------- ; Text-Box - Function for Text, Mtext and Dimension entities ; Arguments: 1 ; Entity^ = Entity name of the Text, Mtext or Dimension to use ; Returns: A list of the four corners of the Text Box ;------------------------------------------------------------------------------- (defun Text-Box (Entity^ / Ang~ AngEntity~ Corners: EntList@ EntNext^ EntType$ First List@ MovePt NewPts@ Pt Return@ Textboxes@ X X1 X3 Y Y1 Y3 Zero) ;----------------------------------------------------------------------------- ; Corners: - Calculates the four corners of the Text Box ;----------------------------------------------------------------------------- (defun Corners: (Entity^ / Ang~ Corners@ Dist~ EntList@ Ins Pt Pt1 Pt2 Pt3 Pt4) (setq EntList@ (entget Entity^) Corners@ (textbox EntList@) Ang~ (cdr (assoc 50 EntList@)) Ins (cdr (assoc 10 EntList@)) Pt (mapcar '+ (car Corners@) Ins) Pt1 (polar Ins (+ Ang~ (angle Ins Pt)) (distance Ins Pt)) Pt (mapcar '+ (cadr Corners@) Ins) Pt3 (polar Ins (+ Ang~ (angle Ins Pt)) (distance Ins Pt)) Dist~ (* (distance (car Corners@) (cadr Corners@)) (cos (- (angle Pt1 Pt3) Ang~))) Pt2 (polar Pt1 Ang~ Dist~) Pt4 (polar Pt3 Ang~ (- Dist~)) );setq (list Pt1 Pt2 Pt3 Pt4) );defun Corners: ;----------------------------------------------------------------------------- (setq EntList@ (entget Entity^) EntType$ (cdr (assoc 0 EntList@)) );setq (cond ((= EntType$ "TEXT") (setq Return@ (Corners: Entity^)) );case ((or (= EntType$ "MTEXT")(= EntType$ "DIMENSION")) (command "UNDO" "MARK") (setq EntNext^ (entlast)) (command "EXPLODE" Entity^) (if (= EntType$ "DIMENSION") (command "EXPLODE" (entlast)) );if (while (setq EntNext^ (entnext EntNext^)) (if (= "TEXT" (cdr (assoc 0 (entget EntNext^)))) (setq Textboxes@ (append Textboxes@ (list (Text-Box EntNext^)))) );if );while (command "UNDO" "BACK") (setq AngEntity~ (angle (nth 0 (nth 0 Textboxes@))(nth 1 (nth 0 Textboxes@))) Zero (list 0 0) First t );setq (foreach List@ Textboxes@ (foreach Pt List@ (setq X (car Pt) Y (cadr Pt)) (if First (setq First nil X1 X Y1 Y) );if (if (< X X1)(setq X1 X)) (if (< Y Y1)(setq Y1 Y)) );foreach );foreach (if (or (< X1 0)(< Y1 0)) (progn (cond ((and (< X1 0)(< Y1 0))(setq MovePt (list X1 Y1))) ((< X1 0)(setq MovePt (list X1 0))) ((< Y1 0)(setq MovePt (list 0 Y1))) );cond (command "UCS" "M" MovePt) );progn );if (setq First t) (foreach List@ Textboxes@ (foreach Pt List@ (setq Ang~ (- (angle Zero Pt) AngEntity~)) (setq Pt (polar Zero Ang~ (distance Zero Pt))) (setq X (car Pt) Y (cadr Pt)) (if First (setq First nil X1 X X3 X Y1 Y Y3 Y) );if (if (< X X1)(setq X1 X)) (if (< Y Y1)(setq Y1 Y)) (if (> X X3)(setq X3 X)) (if (> Y Y3)(setq Y3 Y)) );foreach );foreach (command "UCS" "W") (setq NewPts@ (list (list X1 Y1)(list X3 Y1)(list X3 Y3)(list X1 Y3))) (foreach Pt NewPts@ (setq Ang~ (+ (angle Zero Pt) AngEntity~)) (setq Pt (polar Zero Ang~ (distance Zero Pt))) (setq Return@ (append Return@ (list Pt))) );foreach );case );cond Return@ );defun Text-Box ;------------------------------------------------------------------------------- (princ);End of c:T2M.lsp
Well I modified it, I replaced his rotate with a different command since I couldn't remove the statement without breaking the entire code, I also copied the angle from DXF code 50 on the text to the DXF code 50 on the mtext. It appears to work now, but I have no idea why he didn't do this in the first place, nor do I understand why I couldn't just remove the rotate but had to replace it... Weird. Thank god it works though, half of this I barely understand.
Code:;------------------------------------------------------------------------------- ; Program Name: T2M - Text to Mtext ; Created By: Terry Miller (Email: terrycadd@yahoo.com) ; (URL: http://web2.airmail.net/terrycad) ; Date Created: 7-17-08 ; Function: Changes Text to Mtext ;------------------------------------------------------------------------------- ; Revision History ; Rev By Date Description ;------------------------------------------------------------------------------- ; 1 TM 7-17-08 Initial version ;------------------------------------------------------------------------------- ; c:T2M - Text 2 Mtext ;------------------------------------------------------------------------------- (defun c:T2M (/ Angle~ Cnt# Color# Dxf10 Dxf11 Dxf72 Dxf73 EntList@ EntName^ InsPt Justify# Layer$ MTextPts@ Osmode# P1 P2 SS& Text$ TextPts@ TextSize~ TextStyle$ Width~ ) (princ "\nSelect Text to change to Mtext.") (if (setq SS& (ssget (list '(0 . "TEXT")))) (progn (command "UNDO" "BEGIN") (setq Osmode# (getvar "OSMODE")) (setvar "OSMODE" 0) (setvar "CMDECHO" 0) (setq Cnt# 0) (repeat (sslength SS&) (setq EntName^ (ssname SS& Cnt#)) (setq EntList@ (entget EntName^)) (setq Text$ (cdr (assoc 1 EntList@))) (setq TextStyle$ (cdr (assoc 7 EntList@))) (setq Layer$ (cdr (assoc 8 EntList@))) (setq Dxf10 (cdr (assoc 10 EntList@))) (setq Dxf11 (cdr (assoc 11 EntList@))) (setq TextSize~ (cdr (assoc 40 EntList@))) (setq Angle~ (cdr (assoc 50 EntList@))) (setq Angkeep (cdr (assoc 50 Entlist@))) (setq Color# (cdr (assoc 62 EntList@))) (setq Dxf72 (cdr (assoc 72 EntList@))) (setq Dxf73 (cdr (assoc 73 EntList@))) (setq Justify# (cond ((and (= Dxf72 0) (= Dxf73 3)) 1) ;TL ((and (= Dxf72 1) (= Dxf73 3)) 2) ;TC ((and (= Dxf72 2) (= Dxf73 3)) 3) ;TR ((and (= Dxf72 0) (= Dxf73 2)) 4) ;ML ((and (= Dxf72 1) (= Dxf73 2)) 5) ;MC ((and (= Dxf72 2) (= Dxf73 2)) 6) ;MR ((and (= Dxf72 0) (= Dxf73 1)) 7) ;BL ((and (= Dxf72 1) (= Dxf73 1)) 8) ;BC ((and (= Dxf72 2) (= Dxf73 1)) 9) ;BR ((and (= Dxf72 4) (= Dxf73 4)) 5) ;MC ((and (= Dxf72 1) (= Dxf73 0)) 8) ;BC ((and (= Dxf72 2) (= Dxf73 0)) 9) ;BR (t 7) ;BL ) ;cond ) ;setq (if (= Justify# 7) (setq InsPt Dxf10) (setq InsPt Dxf11) ) ;if (setq TextPts@ (Text-Box EntName^)) (setq Width~ (distance (nth 0 TextPts@) (nth 1 TextPts@))) (setq P1 (polar (nth 0 TextPts@) (angle (nth 0 TextPts@) (nth 2 TextPts@)) (/ (distance (nth 0 TextPts@) (nth 2 TextPts@)) 2.0) ) ) ;setq (command "ERASE" EntName^ "") (entmake (list '(0 . "MTEXT") '(100 . "AcDbEntity") '(67 . 0) (cons 410 (getvar "CTAB")) ;Layout name (cons 8 Layer$) ;Layer name '(100 . "AcDbMText") (cons 10 InsPt) ;Insertion (cons 40 TextSize~) ;Text size '(41 . 0.0) (cons 71 Justify#) ;Justification '(72 . 5) (cons 1 Text$) ;Text value (cons 7 TextStyle$) ;Text style '(210 0.0 0.0 1.0) '(11 1.0 0.0 0.0) (cons 42 Width~) ;Textbox width (cons 43 TextSize~) ;Text size (cons 50 Angkeep) ;Angle ;'(50 . 0.0) '(73 . 1) '(44 . 1.0) ) ) ;list;entmake (if Color# (command "CHPROP" (entlast) "" "C" Color# "") ) ;if (prin1 "Text has been fixed!!") (setq MTextPts@ (Text-Box (entlast))) (setq P2 (polar (nth 0 MTextPts@) (angle (nth 0 MTextPts@) (nth 2 MTextPts@)) (/ (distance (nth 0 MTextPts@) (nth 2 MTextPts@)) 2.0) ) ) ;setq (command "MOVE" (entlast) "" P2 P1) (setq Cnt# (1+ Cnt#)) ) ;repeat (setvar "OSMODE" Osmode#) (command "UNDO" "END") ) ;progn ) ;if (princ) ) ;defun c:T2M ;------------------------------------------------------------------------------- ; rtd - Radians to degrees ;------------------------------------------------------------------------------- (defun rtd (Rad~) (* 180.0 (/ Rad~ pi)) ) ;defun rtd ;------------------------------------------------------------------------------- ; Text-Box - Function for Text, Mtext and Dimension entities ; Arguments: 1 ; Entity^ = Entity name of the Text, Mtext or Dimension to use ; Returns: A list of the four corners of the Text Box ;------------------------------------------------------------------------------- (defun Text-Box (Entity^ / Ang~ AngEntity~ Corners: EntList@ EntNext^ EntType$ First List@ MovePt NewPts@ Pt Return@ Textboxes@ X X1 X3 Y Y1 Y3 Zero ) ;----------------------------------------------------------------------------- ; Corners: - Calculates the four corners of the Text Box ;----------------------------------------------------------------------------- (defun Corners: (Entity^ / Ang~ Corners@ Dist~ EntList@ Ins Pt Pt1 Pt2 Pt3 Pt4 ) (setq EntList@ (entget Entity^) Corners@ (textbox EntList@) Ang~ (cdr (assoc 50 EntList@)) Ins (cdr (assoc 10 EntList@)) Pt (mapcar '+ (car Corners@) Ins) Pt1 (polar Ins (+ Ang~ (angle Ins Pt)) (distance Ins Pt)) Pt (mapcar '+ (cadr Corners@) Ins) Pt3 (polar Ins (+ Ang~ (angle Ins Pt)) (distance Ins Pt)) Dist~ (* (distance (car Corners@) (cadr Corners@)) (cos (- (angle Pt1 Pt3) Ang~)) ) Pt2 (polar Pt1 Ang~ Dist~) Pt4 (polar Pt3 Ang~ (- Dist~)) ) ;setq (list Pt1 Pt2 Pt3 Pt4) ) ;defun Corners: ;----------------------------------------------------------------------------- (setq EntList@ (entget Entity^) EntType$ (cdr (assoc 0 EntList@)) ) ;setq (cond ((= EntType$ "TEXT") (setq Return@ (Corners: Entity^)) ) ;case ((or (= EntType$ "MTEXT") (= EntType$ "DIMENSION")) (command "UNDO" "MARK") (setq EntNext^ (entlast)) (command "EXPLODE" Entity^) (if (= EntType$ "DIMENSION") (command "EXPLODE" (entlast)) ) ;if (while (setq EntNext^ (entnext EntNext^)) (if (= "TEXT" (cdr (assoc 0 (entget EntNext^)))) (setq Textboxes@ (append Textboxes@ (list (Text-Box EntNext^))) ) ) ;if ) ;while (command "UNDO" "BACK") (setq AngEntity~ (angle (nth 0 (nth 0 Textboxes@)) (nth 1 (nth 0 Textboxes@)) ) Zero (list 0 0) First t ) ;setq (foreach List@ Textboxes@ (foreach Pt List@ (setq X (car Pt) Y (cadr Pt) ) (if First (setq First nil X1 X Y1 Y ) ) ;if (if (< X X1) (setq X1 X) ) (if (< Y Y1) (setq Y1 Y) ) ) ;foreach ) ;foreach (if (or (< X1 0) (< Y1 0)) (progn (cond ((and (< X1 0) (< Y1 0)) (setq MovePt (list X1 Y1))) ((< X1 0) (setq MovePt (list X1 0))) ((< Y1 0) (setq MovePt (list 0 Y1))) ) ;cond (command "UCS" "M" MovePt) ) ;progn ) ;if (setq First t) (foreach List@ Textboxes@ (foreach Pt List@ (setq Ang~ (- (angle Zero Pt) AngEntity~)) (setq Pt (polar Zero Ang~ (distance Zero Pt))) (setq X (car Pt) Y (cadr Pt) ) (if First (setq First nil X1 X X3 X Y1 Y Y3 Y ) ) ;if (if (< X X1) (setq X1 X) ) (if (< Y Y1) (setq Y1 Y) ) (if (> X X3) (setq X3 X) ) (if (> Y Y3) (setq Y3 Y) ) ) ;foreach ) ;foreach (command "UCS" "W") (setq NewPts@ (list (list X1 Y1) (list X3 Y1) (list X3 Y3) (list X1 Y3) ) ) (foreach Pt NewPts@ (setq Ang~ (+ (angle Zero Pt) AngEntity~)) (setq Pt (polar Zero Ang~ (distance Zero Pt))) (setq Return@ (append Return@ (list Pt))) ) ;foreach ) ;case ) ;cond Return@ ) ;defun Text-Box ;------------------------------------------------------------------------------- (princ) ;End of c:T2M.lsp
