Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,666
    irneb , that would disable the visibility of the selection set for all open drawings .
    e.g , try to move any entity in any opened drawing and you will find out that the high lighting objects would be disabled when you try to select any object.
    Regards.
    - When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
  2. #12
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,666
    Yes, it's one of the painful aspects of only using portions of the Express tools. You could always allow for such things by saving the value of Highlight and the restoring it at the end of the function.
    I.e. something like this:
    Code:
    (defun c:MExTrim  (/ highlight *error* ss n en ed enA minpt maxpt dx dy pt dxx dyy)
      (vl-load-com)
      (setq highlight (getvar "HighLight"))
      (defun *error* (msg)
        (if highlight (setvar "HighLight" highlight))
        (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **")))
        (princ))
      (prompt "\nSelect closed entities: ")
      (if (setq ss (ssget (append (list '(-4 . "<or")        '(0 . "CIRCLE")      '(-4 . "<and")       '(0 . "*POLYLINE")
                                        '(70 . 1)            '(-4 . "and>")       '(-4 . "<and")       '(0 . "SPLINE")
                                        '(70 . 11)           '(-4 . "and>")       '(-4 . "<and")       '(0 . "ELLIPSE")
                                        '(41 . 0.0))
                                  (list (cons 42 (* 2 pi)))
                                  (list '(-4 . "and>") '(-4 . "or>")))))
        (progn (setq n (sslength ss))
               (while (>= (setq n (1- n)) 0)
                 (setq en  (ssname ss n)
                       ed  (entget en)
                       enA (vlax-ename->vla-object en))
                 (vla-getboundingbox enA 'minpoint 'maxpoint)
                 (setq minpt (vlax-safearray->list minpoint)
                       maxpt (vlax-safearray->list maxpoint))
                 (setq dx (- (car maxpt) (car minpt)))
                 (setq dy (- (cadr maxpt) (cadr minpt)))
                 (setq pt '(0.0 0.0 0.0))
                 (while (not (ptinsideent pt en))
                   (setq dxx (* dx (rnd)))
                   (setq dyy (* dy (rnd)))
                   (setq pt (list (+ (car minpt) dxx) (+ (cadr minpt) dyy) 0.0)))
                 (etrim en pt))))
      (*error* nil))
    Edit: Oh and BTW, thanks marko - that works great even on polylines!
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  3. #13
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,666
    Looks interesting indeed .
    sub-function ptinsideent is missing
  4. #14
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    16GB-1600MHz
    Architectural
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,666
    Quote Originally Posted by Tharwat View Post
    Yes, that function is part of marko's code. I've taken marko's code and only shown the defun where I've modified it to include for the highlight reset.
  5. #15
    Forum Newbie
    AutoCAD 2011
    Apr 2012
    6
    This routine is resulting in everything outside of my circles being trimmed, leaving the portion of line inside as per #3 in ReMark's sketch above. Is there a setting that I could change for it to result in #2 in ReMark's sketch?
  6. #16
    Forum Newbie
    AutoCAD 2010
    May 2012
    4
    Hi,
    Really its very useful ...........
    thank you,
  7. #17
    Full Member
    Land Desktop 2009
    Sep 2011
    54
    Hi Irneb,
    I'm not well versed in lisp where to put. Please give the full lisp.thanks
  8. #18
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    16GB-1600MHz
    Architectural
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,666
    Copy marko_ribar's code from post #10, then replace the last portion starting with
    Code:
    (defun c:MExTrim ...
    with my code from post #12. Save all into a LSP file (normal text file just with a LSP extension instead of TXT). Then load that file into ACad - several ways. Then after that any defun in that file with a name starting with C: becomes a new command with the rest of the name (in this case MExTrim).
  9. #19
    Senior Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2012
    Feb 2010
    Belgrade, Serbia, Europe
    358
    I've modified my code according to BIGAL's discovery that on older Acad versions (etrim ent pt) won't work correctly without (acet-error-init) function and at the end followed by (acet-error-restore)... Look here for details...
    So here is complete code :
    Code:
    (defun rnd (/ modulus multiplier increment rand)
      (if (not seed)
        (setq seed (getvar "DATE"))
      (setq modulus    65536
            multiplier 25173
            increment  13849
            seed  (rem (+ (* multiplier seed) increment) modulus)
            rand     (/ seed modulus)
    (defun GroupByNum ( l n / f )
      (defun f ( a b )
        (if (and a (< 0 b))
          (cons (car a) (f (setq l (cdr a)) (1- b)))
      (if l (cons (f l n) (GroupByNum l n)))
    (defun ptonline ( pt pt1 pt2 / vec12 vec1p d result )
      (setq vec12 (mapcar '- pt2 pt1))
      (setq vec12 (reverse (cdr (reverse vec12))))
      (setq vec1p (mapcar '- pt pt1))
      (setq vec1p (reverse (cdr (reverse vec1p))))
      (setq vec2p (mapcar '- pt2 pt))
      (setq vec2p (reverse (cdr (reverse vec2p))))
      (setq d (distance '(0.0 0.0) vec12) d1 (distance '(0.0 0.0) vec1p) d2 (distance '(0.0 0.0) vec2p))
      (if (equal d (+ d1 d2) 1e-8) (setq result T) (setq result nil))
      result
    (defun ptinsideent ( pt ent / msp ptt xlin int k kk tst result )
      (vl-load-com)
      (setq msp (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
      (setq ptt (vlax-curve-getclosestpointto ent pt))
      (setq xlin (vla-addxline msp (vlax-3d-point pt) (vlax-3d-point ptt)))
      (setq int (GroupByNum (vlax-invoke (if (eq (type ent) 'ENAME) (vlax-ename->vla-object ent)) 'intersectwith xlin acExtendBoth) 3))
      (setq int (vl-sort int '(lambda (a b) (< (vlax-curve-getparamatpoint xlin a) (vlax-curve-getparamatpoint xlin b)))))
      (setq k 0)
      (while (< (setq k (1+ k)) (length int))
        (if (and (eq (rem k 2) 1) (ptonline pt (nth (- k 1) int) (nth k int))) (setq tst (cons T tst)) (setq tst (cons nil tst)))
      (setq tst (reverse tst))
      (setq k 0)
      (mapcar '(lambda (x) (setq k (1+ k)) (if (eq x T) (setq kk k))) tst)
      (vla-delete xlin)
      (if kk
        (if (eq (rem kk 2) 1) (setq result T) (setq result nil))
        (setq result nil)
      result
    (load "extrim.lsp")
    (defun c:MExTrim ( / highlight *error* ss n en ed enA minpt maxpt dx dy pt dxx dyy ) (vl-load-com)
      (acet-error-init (list
                         (list   "cmdecho" 0
                               "highlight" highlight
                               "regenmode" 1
                                  "osmode" 0
                                 "ucsicon" 0
                              "offsetdist" 0
                                  "attreq" 0
                                "plinewid" 0
                               "plinetype" 1
                                "gridmode" 0
                                 "celtype" "CONTINUOUS"
                               "ucsfollow" 0
                                "limcheck" 0
                         T     ;flag. True means use undo for error clean up.
                         '(if redraw_it (redraw na 4))
                        );list
      );acet-error-init
        (if highlight (setvar "highLight" highlight))
        (princ))
      (if (setq ss (ssget (append (list '(-4 . "<or") '(0 . "CIRCLE") '(-4 . "<and") '(0 . "*POLYLINE") '(70 . 1) '(-4 . "and>") '(-4 . "<and") '(0 . "SPLINE") '(70 . 11) '(-4 . "and>") '(-4 . "<and") '(0 . "ELLIPSE") '(41 . 0.0)) (list (cons 42 (* 2 pi))) (list '(-4 . "and>") '(-4 . "or>")))))
            (setq en (ssname ss n) ed (entget en) enA (vlax-ename->vla-object en))
            (setq
            (etrim en pt)
      (setvar 'highlight highlight)
    Regards, M.R.
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  1. select objects inside circle
    By mauro in forum AutoCAD General
    Last Post: 28th Aug 2008, 06:04 pm
  2. Cannot Trim Circle between tangents
    By Bane in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Mar 2008, 02:13 am
  3. Trim inside circle
    By Cube3 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Sep 2007, 07:26 am
  4. Text inside a circle
    By ebjco in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Nov 2005, 07:38 pm
  5. Text inside a circle
    Last Post: 22nd Nov 2005, 04:27 pm
Tags for this Thread
