Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 29
  1. #11
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    I think if I were a student I would want to be learning next-generation CAD tools.
    http://www.autodesk.com/edcommunity
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  2. #12
    Super Member Tankman's Avatar
    Tankman's Computer Details
    XP Pro SP3
    IBM T60 Thinkpad™
    36" LCD Monitor/TV, 14" Thinkpad™ T60
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,794
    Quote Originally Posted by JD Mather View Post
    Excellent post Mr. Mather!
    I'm from the very old school and have a tough time learning new "tricks." All my work in AutoCAD has been simple plan and elevation views; pipe, valves, pumps, chemical storage tanks. An add-on for AutoCAD draws all the pipe, fittings, valves, a great add-on!
    All are ANSI and the program will generate a BOM for me if needed.
    I believe John wanted a 10 x 14 base, a 6" x 6" top, elevation of 6".
    Perhaps you could post John's configuration if you are so inclined.
    If we had the technology 40+ years ago, life in the sheetmetal business certainly would have been easier.
    Tankman
    "When the well is dry, we know the worth of water." Ben Franklin ~ 1746
  3. #13
    Forum Newbie
    AutoCAD 2008
    Nov 2009
    5
    Quote Originally Posted by StykFacE View Post
    When you mean "pattern" are you meaning you need to create a flat pattern that will be fed to a plasma or cutter? Or do you just need to represent a transition dimensionally so that a fab shop can produce the transition for you?
    Hello! may be this real better explain what i mean. thank for helping054042.pdf please see bottom of page 19
  4. #14
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Quote Originally Posted by drafterjohn773 View Post
    Hello! may be this real better explain what i mean. thank for helpingAttachment 15618 please see bottom of page 19
    I would hate to have to work off only those written instructions without any drawings or sketches. Didn't I see a reference to some figures (I didn't find any) or did I miss something?
  5. #15
    XP Pro SP3
    IBM T60 Thinkpad™
    AutoCAD 2007
    Mar 2008
    Eastern PA, USA
    1,794
    I'm guessing John received dimensions verbally from his instructor.
    Naturally a sketch would've been welcome.
    On another note, my Grandfather was the plant manager for Stroehman Bakery in Williamsport for many years.
    During the summer, for us youngsters, entertainment was Little League games.
    Tankman
  6. #16
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Quote Originally Posted by Tankman View Post
    Small world.
  7. #17
    Full Member
    AutoCAD 2010
    Jan 2012
    30
    Default Plate 3 help
    Hi,
    I've started to work on Plate 3 of the HVAC project. I have no idea what to do next. I am unable to figure it out. Can someone please help and talk me through the next steps
  8. #18
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    What textbook are you using to learn Developments?
    I would start by drawing line A-B.
    Then at B draw a circle R B-10' and at A draw a circle R A-10'
    Where they intersect is point 10. Label this and draw true length lines A-10 and B10.
    Attach the file here for next step.
  9. #19
    Full Member
    AutoCAD 2010
    Jan 2012
    30
    Default Plate 3 Help
    Hi,
    I think I have done what you described. I drew line A-B and at each point A and B I drew a 10" radius circle with A and B as the center. Then drew line A-10 and B-10. However this line is shorter than what is on the front view. So now I am really confused. I have attached the file as you asked. As I mentioned before the only textbooks I was using is what was provided by Penn Foster. I have also attached the booklet that describes what I need to accomplish.
  10. #20
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Where did you get 10" radius?
    You have a point #10.
    You solved for true length of line from point A to point #10' (that is 10 prime - new designation for position of point. Not 10 feet. Not 10 inches)
    That pdf is probably copyrighted. I suggest you remove it. It is one thing to post a relavent image from the pdf and quite another to attach the entire file.
    The pdf refers to, "
    Follow the instructions in the text to find the true lengths of
    all the lines. Label the true lengths of the lines as you create
    them."
    But any text I have seen shows the true length projection labele like A-10' (10 prime)
    The R A-10' and B-10' is actually 18.38477631 inches.
  1. Penn Foster
    By bracken2 in forum Student Project Questions
    Last Post: 9th Aug 2011, 11:11 pm
  2. Now WHAT IS THIS!> penn foster help!
    By paisis123 in forum Student Project Questions
    Last Post: 4th Aug 2011, 09:02 pm
  3. Penn Foster help with HVAC/sheet metal Drafting
    Last Post: 15th Jun 2011, 10:19 pm
  4. Transition Piece patterns
    By engineer1 in forum Autodesk Inventor
    Last Post: 2nd May 2006, 02:17 pm
  5. HVAC transition piece
    By engineer1 in forum AutoCAD Beginners' Area
    Last Post: 3rd Apr 2006, 09:34 pm
