Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
  1. #21
    Full Member
    AutoCAD 2010
    Jan 2012
    30
    Hi,
    I think I followed the text correctly to find the true lengths. It's what to do next that I am stuck at. I think I have what you said correct now.
    Thank you so much for helping me and everyone on these forums out especially on a Saturday.
  2. #22
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Oops, I just noticed that the circle is offset from center so B-10' is not equal to A-10'
    Your circles don't look like perfect radius.
    Don't type in the radius - use snap points.
    Your next step will be to determine the length of arc from 10-9.
    Not the cord length (many books miss this) you need the arc length.
    Once you find this it is the same for all (9-8 is the same as 10-9).
    Tip- you can find the arc length by
    copy and paste pie shape away from the drawing.
    trim the pie
    list the arc
    Draw circle of R 10-9 arc length at point 10' in your flat development..
    Draw circle of R A-9' at point A
    Where these two circle intersect is point 9' you now have line A-9
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  3. #23
    Full Member
    AutoCAD 2010
    Jan 2012
    30
    No, its not centered. Do I have this first stage correct?
  4. #24
    Full Member
    AutoCAD 2010
    Jan 2012
    30
    Ok, I have done that step, hopefully correct
  5. #25
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,058
    I'm not at my CAD computer thus the reason for my question. Are you working on the Penn-Foster HVAC project?
  6. #26
    Full Member
    AutoCAD 2010
    Jan 2012
    30
    Yes I am. I have seen the pictures of Plate 3 posted. It shows that the end result is supposed to be but not how to get there. I attached a picture of where I have reached. I assume I do the same thing on the left side but not sure what to do next on the right.
  7. #27
    Full Member
    AutoCAD 2010
    Jan 2012
    30
    This is what I have come up with following instructions that I found online, though they were for a symmetrical piece. I know something is wrong as my arc on the inside isn't correctly meeting the lines for each point. However, I do not know what. Please help when able.
  8. #28
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    It should be a spline curve - not an arc.
    But you have point D in the wrong location.
    Draw circle R A-D at A.
    Draw circle R A-7 with center at 7 (A-7 and 7-D are same length).
    Where these two circles intersect is the actual location of point D.
  9. #29
    Full Member
    AutoCAD 2010
    Jan 2012
    30
    HI,
    Think I have it all correct now...hopefully
  1. Penn Foster
    By bracken2 in forum Student Project Questions
    Last Post: 9th Aug 2011, 11:11 pm
  2. Now WHAT IS THIS!> penn foster help!
    By paisis123 in forum Student Project Questions
    Last Post: 4th Aug 2011, 09:02 pm
  3. Penn Foster help with HVAC/sheet metal Drafting
    Last Post: 15th Jun 2011, 10:19 pm
  4. Transition Piece patterns
    By engineer1 in forum Autodesk Inventor
    Last Post: 2nd May 2006, 02:17 pm
  5. HVAC transition piece
    By engineer1 in forum AutoCAD Beginners' Area
    Last Post: 3rd Apr 2006, 09:34 pm
