Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie
    AutoCAD 2012
    Apr 2012
    4
    Smile Drawing template won't insert in layout
    Hi Everyone, I am using Autocad 2012,
    I made a drawing frame template up in model space, then saved it into the DWT template folder, when I go into Layout and into insert to insert the template it will not show up.
    I reloaded the DWT template back into model space and saved it as a DXF and I am able to insert the dxf template in Layout using the insert Block
    I would like some help please in finding out why the DWT will not insert.
    I can get the job done by using the dxf template but I would like to be able to insert the DWT template
    Thanks for any help
    Regards
    Alan
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    save it as .dwg, I don't think you can insert .dwt, it is not a choice when using Insert command.
    Maybe tell us why you want it to be a dwt file, what the goal is for that file.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
    Forum Newbie
    AutoCAD 2012
    Apr 2012
    4
    Smile
    Hi There, Rkent - (thanks for a speedy response)
    Reason...? Only because when I click for a template it goes directly to DWT folder
    Is using a DXf Template ok? I just tried the dxf format to see if it worked and it did, it got the job done but it would be good if I can use the correct method for inserting a drawing frame. I haven't used Acad for over 6 years, I'm retired now and just helping my son out
    If I save it as a dwg where do I store it for regular use as a template?
    Thanks again for the reply
    Alan
    Quote Originally Posted by rkent View Post
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    I have a folder just for title blocks (.dwg) and I have a template file (.dwt) with all my settings for dims, text, layers, pagesetups, etc. The template name is set in options, files, template for qnew, so anytime I start a new drawing it grabs that template. The title block is xrefed into the template so when I start a new drawing the template brings in my settings and the title block is there as well. I also insert a block for the title block attribute text so again every new drawing will have everything I need to get going.
  5. #5
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,133
    Whenever you use SAVE AS CTRL+SHIFT+S you have the ability to save your file as one of about a dozen different file types. One of those AutoCAD Drawing Template (*.dwt) is the standard used for templates in Cad. Give it a name you will remember, as you will be using it again. Then, like rkent said in the previous post, set that as your default QNEW template in your OPTIONS (right click in your commandline) > FILES > ........as shown in the image.
  6. #6
    Forum Newbie
    AutoCAD 2012
    Apr 2012
    4
    Thank you Dadgad and RKent for your replies,
    Now this information is great, thank you. Now when I now start Autocad it starts with my configured drawing template settings.
    So if while I am still in Autocad if I need to start another of my templates I just type 'QNEW' and away I go again.
    However my original question is to do with Layout (Paperspace) and the insertion of a purpose made drawing frame, I explained that the only way I have been successful in doing this was to make my drawing frame a block and save it as a DXF. As RKent explained that insert mode in Layout will not work with .DWT. Yet in Layout/Insert there is buttons to click that say 'Layout from Template'. I can remember being able to insert my drawing frames into Layout (paperspace) quite easily, But as I have said It is 6/7 years since I last used Autocad..?. So Is making a block and saving as a DXF incorrect, I can explode the block after insertion to add my perameters etc
    Thanks again for some great responses
    Alan
  7. #7
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    571
    Your drawing frame must be in Paper space in the DWT template file to be inserted as a layout.
  8. #8
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,099
    Place the drawing frame in the layout tab (paper space) in the template (.dwt) if you want to insert "Layout from Template" into another layout tab.
    I prefer to place my titleblocks on a Tool Palette for insertion, since I seldom start from a new template.
  9. #9
    Forum Newbie
    AutoCAD 2012
    Apr 2012
    4
    Hello Gent's, thank you for your replies,
    I have already put the drawing frame in the templates folder as a (.DWT), I have already explained that the drawing frame will not Insert into the layout. RKent has previously explained that 'Insert mode in Layout' will not work with .DWT.
    However I can get the drawing frame into the layout as a saved asa block and saved as .DXF and then in Layout using insert - block
    My original question... was why can't the .DWT frame insert into the layout.... Rkent says that Insert won't work with a .DWT file?
    Regards
    Alan
  10. #10
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    Your drawing frame, title block, should be saved as a .dwg file. I say again, your title block drawing should be a .dwg file.
    You can insert that into your .dwt file and use that for new drawings.
    When you have an existing drawing then insert the .dwg file and not the .dwt file.
    If you put the title lock in the layout of the .dwt then you can use design center to bring that layout into an existing drawing.
  1. Template as layout
    By dumbuser in forum AutoCAD Beginners' Area
    Last Post: 12th Dec 2010, 10:32 pm
  2. Adding template to layout.
    By jeremyjjbrown in forum AutoCAD Beginners' Area
    Last Post: 30th Jan 2010, 12:55 am
  3. Layout from Template
    By jplamarche in forum AutoCAD Drawing Management & Output
    Last Post: 9th Sep 2009, 10:17 pm
  4. Insert a jpeg into template
    By max_the_menace in forum AutoCAD Beginners' Area
    Last Post: 30th Jul 2009, 02:03 pm
  5. Drawing Template vs. Settings Template?
    By umop-3p!sdn in forum AutoCAD Beginners' Area
    Last Post: 20th May 2006, 01:09 am
