Results 1 to 7 of 7
Thread: colors
    Forum Newbie
    AutoCAD 2011
    Apr 2012
    2
    Default colors
    how it works?, the objects are yellow in model space and white on paper space??
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,002
    What are those objects that you are talking about? If is about drawing environment elements (i.e. cursor, background) then you are allowed to choose different colors for those in ModelSpace, respectively PaperSpace.
    Regarding the entities in drawing the only color behaving differently is white (7) that may be shown as black or white to get contrast from background. At least I’m not aware of something else.
    If the question is addressing an exiting issue, since you are talking of yellow and white I suspect that this is only an optical illusion due to different backgrounds in MS / PS. Can you post screenshots of each tab?
    Regards,
    Mircea
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,373
    Either you have an override for that layer color using the layer manager or your current page setup is set to display plot styles.
    So go into the viewport and open the layer manager and see if there is an override for that layer color for the VP.
    Or right click on the tab while in that layout and pick page setup manager, upper right uncheck display plot styles.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
    Forum Newbie
    AutoCAD 2011
    Apr 2012
    2
    FOUND IT!!! Thank you very much!!!
  5. #5
    Super Member Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Independent Architectural Draftsman
    Construction
    Residential Homes, Construction and Renovation
    AutoCAD LT 2009
    Feb 2010
    Chuluota, Florida
    1,770
    Quote Originally Posted by KRYZZ View Post
    Found what? The specific solution might help others.
    Yogi Berra: "In theory there is no difference between theory and practice. In practice there is."
  6. #6
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,002
    @rkent: I have to admit that wasn’t aware of those features, though the layer properties override is available from AutoCAD 2011 only.
    Have learned something new today. Thank you for this information!
    Regards,
    Mircea
  7. #7
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    Dana W One of the guys here decided he would play with setting different colors in the viewport v's the model I went round in circles for considerble time before I found that you could do this, its in the layer manager on the right side you can change colour. Told him never do again !
  1. Change pastel colors to alternative colors by layer & elements & blocks
    By deucer in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Jul 2010, 06:13 pm
  2. Colors
    By harley558 in forum Autodesk Inventor
    Last Post: 20th Apr 2010, 08:07 pm
  3. STB and colors
    By MarkytheSparky in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th May 2008, 09:11 pm
  4. Colors are wrong
    By Bluejay Fusion in forum AutoCAD General
    Last Post: 21st Apr 2007, 01:59 pm
  5. layer colors
    By bluemole in forum AutoCAD Beginners' Area
    Last Post: 2nd Aug 2006, 05:46 pm
