Results 1 to 6 of 6
    Full Member
    AutoCAD 2012
    May 2011
    Texas USA
    88
    Default AutoCAD Mechanical 2012
    When I go to put content in a drawing, it tells me that the content path cannot be found, or has be remnamed or moved. It just worked afew days ago and now it tells me this. Does anyone know anthing about this or has had the same problem.
    It is a student lisence by the way. Just wanted to try and it makes it alot easier.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,373
    The path to that is missing, first thing to do is shut down AutoCAD Mech and restart. If that doesn't work then try starting with a new AutoCAD Mech profile.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,124
    I moved this thread to the Mechanical forum.
    Full Member
    AutoCAD 2012
    May 2011
    Texas USA
    88
    I'm Sorry I put this in the wrong forum. My fault. Are you saying to uninstall it and then reinstall it again. Will that work with a Student License? Is that what you mean by shutting it down?
  5. #5
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,373
    Quote Originally Posted by CADLee View Post
    No don't uninstall anything. I am saying to exit AutoCAD Mechanical and then open it back up again. Is the problem fixed? If no then exit ACAD Mech again.
    Now you need to try a different profile for ACAD Mech.
    To start AutoCAD Mech with a new profile (copy the shortcut on the desktop, right click on shortcut, go to Shortcut tab, in the Target line after the first statement in quotes you may have a /p profile_name, over write that if it is there with /p newprofile (pick any name that doesn't already exist in your profile folder), and if you don't have a /p profile_name then simply add the /p newprofile to that line. Pick ok, then double click on the icon, AutoCAD will start with the new clean profile, open a drawing and see if you have the same trouble. If not then you have a problem in your regular profile, usually a path statement that is not correct.
  6. #6
    Full Member
    AutoCAD 2012
    May 2011
    Texas USA
    88
    I seemed to have fixed the problem without doing what was mentioned above. I went to the program features, which in XP was AdD and Remove and I repaired the progrom and whgen I started if back up again, I had found that all the features worked as before. Thanks for all the help. I really appreciate it. Just wanted to let yall know if it happens to someone esle that this might be a easier fiz for some.
    Thanks Again.
  1. AutoCad Mechanical 2012 - Creating and editing BOM's
    By CadMonkey in forum Mechanical
    Last Post: 6th Mar 2012, 07:17 am
  2. AutoCAD Mechanical 2012 Service Pack 1
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 20th Sep 2011, 01:50 am
  3. AutoCad Mechanical 2012; Cross hairs
    By JKehler in forum AutoCAD General
    Last Post: 16th Sep 2011, 02:08 pm
  4. Replies: 0
    Last Post: 14th May 2011, 02:40 am
  5. Replies: 0
    Last Post: 8th Apr 2011, 05:30 pm
