+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Forum Newbie
    Using
    Architecture 2012
    Join Date
    Apr 2012
    Posts
    3
    Default 3d sectionplane on walls
    I am using AutoCAD Architecture 2012.
    I built some walls and a roof slab using the wall, door, and roof slab tools in the build section of the ribbon. I drew a sectionplane and activated livesection. The walls and roof did not cut away and they do not show up when i use the sectionplanetoblock command.
    Is there a setting I need to change to make the walls and roof susceptible to being cut using the sectionplane command?
  2. #2
    Senior Member
    Computer Details
    bill_borec's Computer Details
    Operating System:
    Windows 7 - 64 Bit
    Computer:
    Dell XPS
    CPU:
    Intel i7-2600
    RAM:
    8 GB
    Graphics:
    AMD Radeon HD 6700
    Monitor:
    Dual 24"s
    Discipline
    Civil
    bill_borec's Discipline Details
    Occupation
    Civil PE
    Discipline
    Civil
    Details
    Water Resources (Water/Sewer/Storm) Water/Wastewater Treatment Design
    Using
    Civil 3D 2013
    Join Date
    Jan 2012
    Location
    43.3630N 124.1947W
    Posts
    166
    Default
    Check layers. (on/off/frozen/thaw). Are all the correct layers on and thaw?
    Ensure the section plane intersects the roof and walls.
    Check the display settings on the live section and section plane created.
  3. #3
    Luminous Being StykFacE's Avatar
    Computer Details
    StykFacE's Computer Details
    Operating System:
    Windows 7 Ultimate 64bit
    Computer:
    Dell Precision T3500
    Discipline
    Multi-disciplinary
    StykFacE's Discipline Details
    Occupation
    BIM Manager & Design Specialist
    Discipline
    Multi-disciplinary
    Details
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,495
    Default
    Is it a 3D Live Section?
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  4. #4
    Forum Newbie
    Using
    Architecture 2012
    Join Date
    Apr 2012
    Posts
    3
    Default
    every layer is on and on thaw. the section place is right in the middle of the building, so it intersects the walls and the roof. What display settings should I be checking? How can I check them?
    Is it possible that the sectionplane and livesection commands do not work on the AEC objects like walls, doors, windows, and roofs? Is there a different way I can go about creating sections of a 3d model?
  5. #5
    Forum Newbie
    Using
    Architecture 2012
    Join Date
    Apr 2012
    Posts
    3
    Default
    it is a 3d livesection.
  6. #6
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,128
    Default
    I know sectionplane/livesection will not work on blocks and exhibits the same behavior you describe, so just a WAG that it doesn't work on AEC objects.
  7. #7
    Computer Details
    Operating System:
    Computer:
    Discipline
    Multi-disciplinary
    Occupation
    Discipline
    Multi-disciplinary
    Details
    Using
    Revit 2013
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    6,495
    Default
    Live Section works in a 3D rotated view only. If you're wanting to make actual "sections", then click the Section Line once, and in the "Building Section Line" Tab, click "Generate Section".
Similar Threads
  1. Replies: 2
    Last Post: 30th Mar 2012, 12:28 am
  2. Sketchup import Sectionplane etc., no go? Why
    By CalypsoArt in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Mar 2011, 10:58 pm
  3. sectionplane problem
    By anndrenaline in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Feb 2010, 06:46 am
  4. Plugins for drawing cavity walls, party walls etc.
    By LukeR in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2007, 08:24 pm
  5. SECTIONPLANE command not working
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 11th Dec 2006, 06:00 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
