Viktorik Posted April 6, 2012 Share Posted April 6, 2012 Hi , cant draw a tan ,tan, radius circle , between 2 splines, it doesn't show any tangent point on a spline ? between two circles or 2 lines, no problems ... Autocad Architecture 2013 64, Thanks! Quote Link to comment Share on other sites More sharing options...
eldon Posted April 6, 2012 Share Posted April 6, 2012 Flatten the two splines first Quote Link to comment Share on other sites More sharing options...
Viktorik Posted April 6, 2012 Author Share Posted April 6, 2012 I Drawed 2 splines from top , so they must be coplanar, or not? If I remember, 2012 had nu such problem... same behind ellipses... Quote Link to comment Share on other sites More sharing options...
eldon Posted April 6, 2012 Share Posted April 6, 2012 If your spline does not show tangent points, then you have to convert it to a polyline. In my version of AutoCAD, that can be done by using FLATTEN, even if everything is already at z=zero. Your version may have some other means of converting. Quote Link to comment Share on other sites More sharing options...
Viktorik Posted April 6, 2012 Author Share Posted April 6, 2012 flatten- unknown for mine, flatshot needs surfaces,solids... Quote Link to comment Share on other sites More sharing options...
eldon Posted April 6, 2012 Share Posted April 6, 2012 Flatten is an Express Tools command. You probably can convert the Spline directly, but I cannot help you there. I personally think that Splines can be a menace, and I would always use a curve fit polyline. Quote Link to comment Share on other sites More sharing options...
Viktorik Posted April 6, 2012 Author Share Posted April 6, 2012 ok, thank you ... I will do other thinks ,I have sent it to autodesk , but they are slow there on forums ... Quote Link to comment Share on other sites More sharing options...
