Results 1 to 5 of 5
    Junior Member
    AutoCAD 2010
    May 2011
    11
    Default Restrict startup = 1 to "Choose a template"
    If I set startup to "1" then at startup, the user is offered four options:
    Open a drawing
    Start from scratch
    Use a template
    Use a wizard
    Once a choice from the above four options is made, from then on, "startup" defaults to the last option that was chosen.
    My question is whether or not there is a setting or registry entry where I can restrict the startup to always going to the "choose a template" screen regardless of the last choice made.
    Thanks for looking
    Luminous Being BlackBox's Avatar
    BlackBox's Computer Details
    Windows 8.1 Professional, Server 2012 R2 Datacenter
    Dell Precision T3600
    Hex-Core Intel Xeon 3.2Ghz
    32GB
    3GB NVIDIA Quadro K4000
    2 x 240GB Samsung EVO SSD (RAID 0)
    1TB Western Digital VelociRaptor 10K RPM
    Dual 24" Dell Ultrasharp Widescreen Monitors
    Civil
    BlackBox's Discipline Details
    Senior Civil Designer
    Civil
    Public/Private Land Development, Transportation, and Utilities.
    Civil 3D 2016
    Nov 2009
    5,282
    I am unable to test this for myself, but will adding this to Acad.slp or AcadDoc.lsp not work?
    Code:
    (if (/= 1 (getvar 'startup))
      (setvar 'startup 1))
    FWIW - Edwin's article on this topic may be useful:
    AutoCAD 2012: Option to start without opening a file
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    Sincpac C3D ~ Exchange Apps ~ Autoloader ~ AutoCAD Security
    Junior Member
    AutoCAD 2010
    May 2011
    11
    Thanks for the response.
    The issue is not permanently setting the startup system variable to "1". The issue is:
    if the startup variable is set to "1" , can the default screen be "use a template" regardless of what screen was chosen in the previous instance?
    For example: If startup is set to "1" and in the last instance of AutoCad, the user selected the "start from scratch" screen, then the next time AutoCad is loaded, startup will display the "start from scratch" screen. (AutoCad apparantly defaults to the last choice)
    What I would like to do is (assuming startup is set to "1") is force AutoCad to always display the "Choose a template" screen as opposed to displaying the screen that was used in the last instance.
    Thanks again
    32GB
    Civil
    Civil
    Civil 3D 2016
    Nov 2009
    5,282
    Sounds like the registry (or local %AppData%) is storing the last used screen. If you can identify the file or registry key being used, then you can control during startup or drawing open.
  5. #5
    AutoCAD 2013
    Nov 2011
    6,031
    Sounds like you want to use _NEW as your startup command, which will take you directly to your template dialog window.
    Set you STARTUP system variable to '0', and delete any default QNEW template selection which may have been designated in your OPTIONS > FILES > none ..........
    Set like in the image you will get what you are hoping for.
  1. "New Features Workshop" in startup of ACAD2010
    By khoshravan in forum AutoCAD General
    Last Post: 23rd Dec 2011, 04:27 pm
  2. AutoCAD window start to "hang" at startup.
    By keren84 in forum AutoCAD General
    Last Post: 17th Feb 2011, 03:18 pm
  3. "Customization file load failed.....acadlt.cui" profile access error on startup
    By Scott345 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 5th Aug 2010, 02:00 pm
  4. Replies: 0
    Last Post: 16th Sep 2007, 07:40 am
  5. "LINK template" icons "greyed out" -why?
    By Chrisjpritchard in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2007, 10:25 pm
