Results 1 to 4 of 4
    Forum Newbie
    Civil 3D 2012
    Apr 2012
    5
    Angry Composite volume calculation
    I was going through the tutorials for the above topic.Intrying to create the base surface and the create surface dialog box shows up, then I have a problem.
    After entering the TYPE: Tin Volume Surface.
    Descriptionxxxxxx
    STYLE: STANDARD This is my problem area. The drop downs do not have Standard in them. What should I do ? Somebody help me pleeeease!
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,000
    Can you clarify please about what command are you talking here?
    Or, provide the link to the said tutorial - since you are a new user is possible that the post with link will require moderators approval.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Are you using vanilla AutoCAD or are you using Civil 3D?
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Forum Newbie
    Civil 3D 2012
    Apr 2012
    5
    I am using Civil 3D 2012
  1. volume calculation - parallelepiped - lisp
    By flopo in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Jul 2011, 06:20 am
  2. Composite Always Looks For The License
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 27th Dec 2010, 06:30 am
  3. Volume Calculation
    By chap_engineer in forum AutoCAD Beginners' Area
    Last Post: 14th Oct 2010, 02:45 pm
  4. composite layer
    By GoncaloM26 in forum Catch All
    Last Post: 21st Mar 2010, 11:12 pm
  5. volume calculation of a cross-section by rotating around the central axis
    By Brian in forum AutoCAD Drawing Management & Output
    Last Post: 29th Oct 2007, 09:33 pm
Tags for this Thread
