Ardalee Posted April 11, 2012 Share Posted April 11, 2012 I am running Inventor 2011. I have noticed that you can add a vertex / leader with a chamfer or leader text. I need to add a vertex to a diameter / radius dimension. Is there a way to do this? I do not see an option for this in the drop down menu when I right click on my diameter / radius dimensions like I do when I right click on a chamfer or note. Please help. Quote Link to comment Share on other sites More sharing options...
Ardalee Posted April 12, 2012 Author Share Posted April 12, 2012 I will take the lack of response vs the number of views as, "this can not be done." Quote Link to comment Share on other sites More sharing options...
Bishop Posted April 12, 2012 Share Posted April 12, 2012 So far as I've been able to figure, no, you can't do it. What I usually do in those situations is just create leader text and put the dimension in that manually instead of using the dimension command. It's annoying - and it won't auto-update if you change the model - but it does have the virtue of having a vertex when absolutely necessary. Quote Link to comment Share on other sites More sharing options...
