Change Block To Solid And Extrude
Tosagua
I have bee awat from AutoCad for a while. Using 2002.
I inserted an an Angle block from PE Symbols into my Drawing, but it is only 2 dimensional.
I have forgotten how to change the block to a solid, and then to extrude it to a given length.
Any help would be appreciated.
Tosagua
closed polyline (PE Join, you might have to explode first - depending on what you really have).
Extrude
attach your file here.
I appreciate the help.
So the procedure is Explode, PE Join, and then Extrude.
It worked.
Thank you very much.
Tosagua
