Results 1 to 5 of 5
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,994
    Default A trick with numbers
    Code:
    (setq stringNew "")
    (foreach index '(0 1 2 3 4 5)
     (setq stringNew
           (strcat stringNew
                   (chr
                    (fix
                     (atof
                      (rtos (+ (* index
                                  (+ (* index
                                      (+ (* index
                                          (- (* index
                                              (+ (* index
                                                    -0.75)
                                                 7.2917))
                                             22.5))
                                         16.708))
                                     28.25))
                               72)
                            2 0))))))
     (setq stringNew
           (strcat stringNew
                   (chr
                    (fix
                     (atof
                      (rtos
                       (+ (* index
                             (- (* index
                                 (+ (* index
                                     (- (* index
                                         (+ (* index
                                             (- (* index
                                                   0.425)
                                                6.8667))
                                            40.833))
                                        109.58))
                                    122.24))
                                23.05))
                          87)
                       2 0))))))
    (alert stringNew)
    (translated from a Visual Basic 6 routine; author unknown)
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,709
    Reminds me of this:
    Code:
    (   (lambda ( f x ) (f x))
        (lambda ( x ) (eval x))
            (lambda ( x ) (read x))
                (lambda ( x ) (vl-list->string x))
                (   (lambda ( f x ) (mapcar 'f x))
                    (lambda ( x ) (boole 6 90 x))
                        (lambda ( x ) (vl-string->list x))
                        "r;6?(.zx\022?665z\r5(6>{xs"
    Or, 'unobfuscated':
    Code:
    (eval
        (read
            (vl-list->string
                (mapcar
                    (function
                    (vl-string->list "r;6?(.zx\022?665z\r5(6>{xs")
    Lee Mac Programming
    Just another Swamper
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,994
    Nice ones! I especially like the "built-in displaying"...
    Regards,
    Mircea
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,709
    Quote Originally Posted by MSasu View Post
    Certainly fun, but very dangerous in the wrong hands...
    Lee Mac Programming
  5. #5
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,634
    Yep, this type of thing is usually used as a way of hard-coding unlock-codes / passwords so that such can't be readily seen in compiled code by simply viewing an EXE in a hex editor. A simple "hash" function to obfuscate such things. It's not the best method, but works to stop most people from cracking a program - won't stop a determined guy though
    It can be seen as introducing a key into your program. Although this would be like adding a 2 leaver key (i.e. easily pickable with a hairpin).
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  1. Convert integers numbers into real numbers, introducing decimal separator.
    By teknomatika in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Sep 2010, 04:07 pm
  2. Trick question ?
    By Kemion in forum AutoCAD Beginners' Area
    Last Post: 4th Feb 2008, 01:30 pm
  3. Autocad trick
    By ricardfernandes in forum AutoCAD General
    Last Post: 28th Sep 2007, 02:39 pm
  4. That did the trick
    By glazier in forum AutoCAD Beginners' Area
    Last Post: 2nd Mar 2006, 06:11 am
  5. adding numbers to numbers
    By philk in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Feb 2006, 05:45 pm
