Results 1 to 6 of 6
    Forum Newbie chvnprasad's Avatar
    Map 3D 2010
    Mar 2012
    8
    Default Set command in Mouse Right Click
    Hi, I have a doubt regarding Mouse click actions in Autocad. Is there any possibilities to set a autocad command or lisp command to mouse right click. I mean tha if i click mouse right button automatically command need to execute. Presently in autocad when i click right mouse button it shows popup window(In this window showslast command and recent commands list). But i required need to execute assigned command without popup widow. Sorry for my english.
    Thanks in Advance,
    Prasad
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    You would have to edit your CUI to execute the new "assigned" command. Look at Mouse Buttons > Click.
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,131
    You can do this quite easily. You will need to open and tune your OPTIONS. Lots of ways to open your OPTIONS. You will likely find it at the bottom of your right click shortcut menu, or you can right click inside your COMMANDLINE and select it there. OP typed into your commandline will probably do it too.
    If you have not already done so, I would suggest setting up a personal PROFILE and saving it on the PROFILES tab in your OPTIONS, so that it is easy to maintain and restore your personal setting preferences.
    The attachment shows you where to find the RIGHT CLICK CUSTOMIZATION settings. Review and choose appropriate settings to taste. I like to use the TIME SENSITIVE right click option, it is a matter of personal preference, set yours here.
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,630
    Quote Originally Posted by Dadgad View Post
    +1 on the Time Sensitive idea as it gives you both, I hate not being able to get the right-click at all. That way a quick right-click is as if you pressed Enter / Spacebar. A click-and-hold would open the pop-up.
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  5. #5
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,089
    I used to customize ***POP*** on the fly back in 2007 cad version, but for the love of gravy i cant remember how i did it. .
    I think theres an eays way to do that thru CUI. but then again, i dont mess with the menus that much since 2009, i'd stick with Tool palettes.
  6. #6
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    16GB-1600MHz
    Architectural
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,630
    It was probably some sort of toggle on the ShortCutMenu variable. Or even also the ShortcutMenuDuration. These are basically what you're changing in the Options dialog as Dadgad's shown.
  1. Problematic mouse right-click command, selection or input confirmation in AutoCAD2012
    By novator in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Dec 2011, 04:27 pm
  2. Orbit command for middle mouse click
    By mtfer3 in forum AutoCAD Beginners' Area
    Last Post: 13th Oct 2010, 03:20 am
  3. right-click mouse customization
    By StevenNoppe in forum AutoCAD Beginners' Area
    Last Post: 29th May 2009, 12:40 pm
  4. Problem when i click mouse
    By edckute100 in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Nov 2007, 04:32 pm
  5. Mouse Right Click
    By dbroada in forum AutoCAD Drawing Management & Output
    Last Post: 12th Apr 2007, 10:43 am
