onkelbob Posted April 15, 2012 Share Posted April 15, 2012 I opened an old drawing and I have preset aliases, I pressed "L" and with ortho set on I drug my line 19.25 inches. and left clicked and nothing happened. The command line showed 19.25 but there is no line. All layers are turned on. this is what I did : Command: l LINE Specify first point: Specify next point or [undo]: 19.25 Specify next point or [undo]: Command: la LAYER Command: Command: L LINE Specify first point: Specify next point or [undo]: 19.25 Specify next point or [undo]: *Cancel* As upi see I tried it and then because nothing happened I checked layers. Is there a way that my mouse is no longer registering. I can click onto the end of a line and the first point of my line seems to be registering ok. the finishing of the command seems to be failing. Quote Link to comment Share on other sites More sharing options...
onkelbob Posted April 15, 2012 Author Share Posted April 15, 2012 Ok also if I list and select a window around the line I thought I drew. It shows up . Quote Link to comment Share on other sites More sharing options...
onkelbob Posted April 15, 2012 Author Share Posted April 15, 2012 When I lsit the line it shows it to be 78'1.390 wide Ok I changed the thinkness to 0 and all is cool sorry guys Quote Link to comment Share on other sites More sharing options...
onkelbob Posted April 15, 2012 Author Share Posted April 15, 2012 Now I went in and changed thickness to zero and the whole dwg dis appeared now what Quote Link to comment Share on other sites More sharing options...
onkelbob Posted April 15, 2012 Author Share Posted April 15, 2012 I undid the thickness command and the dwg returned When I list the lines in the original dwg there is no indication of thickness in the attributes of the dwg. When I list the new lines there is a thickness listed in the attributes of the list command. I don't know what has happened to the dwg, nor do I know how to fix it. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 16, 2012 Share Posted April 16, 2012 I think you want to toggle off SHOW LINE WEIGHTS. Shown turned on circled in image. Quote Link to comment Share on other sites More sharing options...
