your units??
are you using generic?
you can model the motor case using a line..
just create half of the profile meaning...
look at it from the front and create the outside profile from the center out..
next use loft modifier and move its axis to center and then convert it to editable poly.
what the loft will do is create an empty cylindrical shell using the profile you created.. it will take the spline and revolve it while making geometry .. then add a shell modifier and you decide on inner or outer.
When all else fails..... CTRL+A, DEL, CTRL+S
"Work Smart, Not Hard"
Click to View My Portfolio ( Updated 03/01/2013 ) ---> http://www.rdeweese.com/
