AutoCAD 2013 was recently released and as usual, I’m providing a summary of the major new features so you can decide if you want to upgrade.
New file format
AutoCAD is updated every year, bot only every 3*years or so do they change the file format.* A new file format means that people with earlier releases can’t open drawings creating in the new format. Of course, you can save drawings in an earlier format (going way back, in fact) so that others can open them.
Command line updated
The command line looks different and has several new and updated features. The most important new feature, in my opinion, is that you can click on a command’s options listed on the command line to execute them. Here are some other changes:
  • Recent commands list: Click the down arrow at the left side of the Command line to see a list of recent commands. You can click a command from the list to execute it.
  • Customize icon: Click the customize icon, also that the left side of the Command line, to configure the Autocomplete feature and also open the Options dialog box, where you can click the Colors button on the Display tab, choose Command Line from the Content box, and then specify colors for every feature of the command line.
  • New shortcut for the Text window: To open the Text window, which displays all of your command line input, press Ctrl + F2.
My take: I really like the idea of being able to click options on the command line. That’s where you read through the options to see which one you need, so that’s where your attention is. It’s nice not to have to go somewhere else to choose an option.
Array enhancements
For 2012, AutoCAD introduced a new ribbon-based interface for creating arrays and also added the new path arrays. This time there are some tweaks. When you start a rectangular array, you immediately see a 3 x 4 grid; when you start a polar array, you immediately see 6 items around the center.
Multifunctional grips let you edit properties, such as the number of rows in a rectangular array or the angle between items in the polar array.* But you can still use the ribbon or command line to change properties.
My take: I’m neutral on these changes.
Dynamic preview of changes
When you select an object and hover over an item that will change the way it looks, you see that change before clicking. For example, if you select a black circle, and hover over a layer in your layer drop-down that is red, you’ll see a red circle. This is true whether that layer drop-down is on the ribbon,* the Properties palette, or the Quick Properties palette. You can also preview changes to viewports, visual styles, and more.
If you don’t want this feature, you can turn it off. In the Options dialog box (OPTIONS command), click the Selection tab and uncheck the Property Preview checkbox.
My take: A great feature and long overdue. After all, Microsoft Office has had this feature since Office 2007! You’ll quickly get so used to it that you won’t even realize it’s a new feature.
OFFSET preview
When you use the OFFSET command, you see a preview before you commit to the exact location.
*My take: Another nice feature.
Point Cloud improvements
The Insert tab has a new Point Cloud panel when you’re in the 3D Modeling workspace. You can attach and manage point cloud files similar to the way you work with xrefs. The Properties palette provides more info about point clouds and there’s a new Point Cloud Intensity tool. You can index scanned files from major industrial scanner companies, such as Leica, Topcon, and Faro.
My take: I’ve never used point clouds, except to test them. Do you use point clouds? Is this update important to you? Leave a comment!
VIEWBASE (2D view object) improvements
AutoCAD 2012 introduced the VIEWBASE command to create 2D view objects. (I have a tip on this command here.) 2D view objects lets you show 2D views of your 3D models in a viewport.
AutoCAD 2013 updates view objects significantly:
  • You can select which objects to include.
  • You can add labels and styles. The new Section View Style Manager lets you customize how your 2D view objects look.
  • You can use multifunctional grips to modify the section view, move the section line, add and remove vertices, flip direction, reposition identifiers, and more.
  • You can create details from existing views.
  • You can add associated annotations, e.g. dimensions and multileaders.
  • The new Auto Update tool lets you automatically update 2D view objects when your model changes.
My take: I like 2D view objects and the updates are good additions.
PRESSPULL improved
The PRESSPULL command is more flexible and context sensitive. You can use it to select and extrude 2D and 3D curves, creating surfaces and solids. There’s a new Multiple option so you can select multiple objects, or can you press Shift key to select additional objects. The command now prompts for an extrusion height or offset distance immediately after selection.
My take: These new PRESSPULL features will make the command easier and more useful. It was sometimes a little hard to use before.
Have you upgraded? Are you planning to? What is your favorite new feature? Leave a comment!
More...
