Results 1 to 7 of 7
    Senior Member
    Architectural DT 2008
    Aug 2007
    Houston
    113
    Default wblock to AutoCAD?
    has anyone found a way to -wblock to an older AutoCAD format from Autocad Architecture?
    I have a client (500LB Gorrilla so asking them to get up to speed is out of the question) that runs Autocad 2004 & can't seem to figure out what proxy objects are. So I have to "Export to AutoCAD 2004" any file I send them.
    The problem is I always have to remove certain layers of information that they shouldn't have (area calculations, Architectural seal, etc.)
    My process now is to -wblock out only the part of the drawing they need then open the new file & "export to Autocad" then delete the intermediate file.
    Is there any way to shortcut this process & create the limited file in one pass?
    You never want to shoot yourself in the foot, Especially when it's in your mouth.
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    -ExportToAutoCAD command. Make sure to use the Purge option. Clears all the Proxy Objects, etc.
    http://exchange.autodesk.com/autocad...5b621-7fea.htm
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Senior Member
    Aug 2007
    Houston
    113
    Yeah I know about exporttoautocad, unfortunately it copies everything in the file. Im looking for a way to do what exporttoautocad does but to only selected items.
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,124
    In Vanilla AutoCAD -wblock uses the settings from OPTIONS>Open and Save>File Save>Save As.
  5. #5
    Senior Member
    Aug 2007
    Houston
    113
    Export to autocad goes one step beyond save as. Not only does it change to the older drawing format but it translates AEC objects into simple linework.
    Export to auto cad works on the whole file. -wblock lets you save out a part of your drawing as a new file (of selected file format ie 2004 ,2007, etc).
    I'm looking for some way to save a part of the drawing as an older file format AND translate AEC objects into linework all in one go.
    The only way I've found to make the files I need is to -wblock then export from the wblock & delete the intermediate file - seems like there should be a way to do this all in one step.
  6. #6
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,090
    Maybe you need to be looking at a custom lisp routine since it seems you are forced to do this on a regular basis.
  7. #7
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,124
    I would delete what was not needed, then export to autocad as 2004, then close the drawing WITHOUT saving the changes.
  1. wblock
    By metaldan in forum .NET, ObjectARX & VBA
    Last Post: 13th Mar 2012, 06:03 pm
  2. Wblock
    By CindyLou in forum AutoCAD Drawing Management & Output
    Last Post: 16th Nov 2007, 06:24 pm
  3. Wblock
    By HAPPY HAMMER in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Nov 2007, 12:52 pm
  4. Wblock in VB
    By TroutKing in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th May 2007, 08:37 pm
  5. WBLOCK IN ADT 3.3
    By gguillory in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Feb 2005, 06:15 pm
