Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
  1. #11
    AutoCAD 2013
    Nov 2011
    6,056
    How do you know it is not an image, without knowing what it is? An image doesn't necessarily mean a photograph or drawing, an image can be text based too. I am thinking that CyberAngel may be on the right track here. Try setting your FRAMESELECTION variable to '1' at the commandline. If that doesn't do it, then try setting your PREVIEWFILTER variable to '0' at the commandline.
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    So, where is that drawing file? An "image" doesn't do us any good as far as troubleshooting the problem goes. A drawing file is what we need. If the file is too big then either zip it or cull out all unnecessary content and do a "saveas" to a new file name then attach that drawing instead.
  3. #13
    Junior Member
    AutoCAD 2012
    Apr 2012
    20
    so after getting back to work today, I began messing around with the file. Using "Control + A" did select the text blocks, verifying that they were being read as an entity by AutoCAD. At that point, it would allow me to click on a handle and manipulate it - after I've clicked on the block after selecting it via "control +A" I can continue to manipulate it like any text block without issue.
  4. #14
    Junior Member
    AutoCAD 2012
    Apr 2012
    20
    EDIT: After experimenting with the template, I have realized that the text block will become unselectable once again if I go to another layout tab and return to the layout where the issue is occuring - the text block occurs on all of the other layout tabs without issue.
    If I receive permission from my employer to attach the template later, I will add an update
    Quote Originally Posted by Ty520 View Post
  5. #15
    Junior Member
    AutoCAD 2012
    Apr 2012
    20
    PREVIEWFILTER and FRAMESELECTION do not appear to be valid in AutoCAD 2005
  6. #16
    AutoCAD 2013
    Nov 2011
    6,056
    Your profile indicates that you are using 2009? What file format is this drawing?
  7. #17
    Junior Member
    AutoCAD 2012
    Apr 2012
    20
    I use 2009 - my employer is on 2005
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I've grown a beard waiting for you to post the file. Please attach a drawing before the beard reaches the floor. Thanks.
  1. Objects, text, etc. are highlighted when I pan over
    By nrschmid in forum AutoCAD General
    Last Post: 20th Jun 2010, 06:49 pm
  2. Changing text size of non-objects
    By SanDamiano in forum AutoCAD Beginners' Area
    Last Post: 21st Aug 2008, 06:59 pm
  3. text above objects
    By succu8us in forum AutoCAD General
    Last Post: 5th Aug 2008, 07:16 am
  4. Adding text to 3D Objects
    By Dan in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Oct 2006, 05:16 am
  5. Linked text/objects
    By DanielB in forum AutoCAD General
    Last Post: 28th Sep 2006, 01:25 pm
