Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
    Full Member
    ColinHolloway's Computer Details
    Windows 7
    Dell T1700
    Multi-disciplinary
    ColinHolloway's Discipline Details
    CAD Support Officer
    Multi-disciplinary
    P&ID Structural Civil Mining & Metals Electrical
    AutoCAD 2016
    Oct 2011
    Brisbane, Queensland, Australia
    42
    Default AutoCAD 2012 - 3D Orbit
    Hi All,
    I have having issues with 3D Orbit in AutoCAD 2012. I have attached a drawing that exhibits the symptoms.
    The attached drawing contains blocks and simple entities to define a set of handrails. The original drawing contained all of the platform steelwork and was very slow and jerky when using 3D Orbit. I systematically removed items from the drawing until i was left with these entities.
    When I use 3D orbit in this drawing (zoomed to show full extents) there is a lag between the mouse input and the orbit, however when I explode the blocks, the 3D Orbit works as expected with no perceivable lag between mouse and movement. This is also the case in the original drawing. The performance of the 3D Orbit also recovers when the layer that these entities are on is frozen.
    I was originally suspecting drivers, hardware acceleration and object enablers, but this issue occurs on multiple machines with and without acceleration or OE's.
    Thanks in advance for any input on this issue,
    Colin Holloway
    AutoCAD 2013
    Nov 2011
    6,034
    The problem that you are having is likely because this appears to have been created with PRO STEEL. I opened it and ran '_PURGE', and removed 10 registered apps, and everything else that I could. I also AUDITED it, saved and purged again. It seems to be working just fine now. I had to rename it, as it was write-protected.
    Full Member
    Windows 7
    Dell T1700
    Multi-disciplinary
    CAD Support Officer
    Multi-disciplinary
    AutoCAD 2016
    Oct 2011
    42
    Hi Dadgad,
    Thanks for the quick reply. The steelwork in this drawing was created using ProSteel so that doesn't surprise me. I had also run a purge. I opened your cleaned drawing and I am still seeing a performance difference between blocks and exploded. The drawing from you seems to orbit the same as my original drawing.
    Did you try 3D Orbit after exploding the blocks? If so did you experience an inprovement in orbit performance?
    Colin
    AutoCAD 2013
    Nov 2011
    6,034
    I didn't use the 'PURGE' command, but rather the commandline '-PURGE' command which is much more powerful. I removed the 10 Registerd Applications mentioned in the previous post, which the regular PURGE command is incapable of doing. I didn't bother exploding the blocks because it was orbiting just fine on my machine, with no perceivable problems. I am working on 2012, and there seemed to be no issues whatsoever, very smooth, just as I sent it to you. Might it be quicker exploded? Perhaps, I just don't see where there is any need for greater speed. Are you saving your files as 2010 format, or to an earlier format?
    Funny, I just noticed that the file is actually larger, after cleaning, than it was before, which seems rather counter intuitive. I was rotating it in 2D Wireframe visualstyle, and in an isometric perspective, as saved.
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    What are you system specs?
  6. #6
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,042
    See THIS thread.
  7. #7
    Full Member
    Windows 7
    Dell T1700
    Multi-disciplinary
    CAD Support Officer
    Multi-disciplinary
    AutoCAD 2016
    Oct 2011
    42
    Dadgad,
    The reason I need every bit of 3D Orbit performance I can get is becuase in the original drawing (with the ProSteel structural elements), the 3D Orbit is so slow that Adaptive Degradation kicks in and makes the model difficult to position. When I explode these handrail blocks (or freeze the layer they are on), I can switch Adaptive Degradation off and it still orbits perfectly. If the drawing was only these handrails then I agree, perfomance is acceptable.
    ReMark,
    Intel Xeon W3540 @ 2.93GHz
    16.0 GB RAM
    Windows 7 64 bit
    NVidia Quadro FX 3800 (or Quadro 4000 depending on machine)
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    What is the file size?
  9. #9
    Full Member
    Windows 7
    Dell T1700
    Multi-disciplinary
    CAD Support Officer
    Multi-disciplinary
    AutoCAD 2016
    Oct 2011
    42
    The file size of the original drawing (with ProSteel objects) is 6,030kb.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Fairly large file. Can you freeze some layers to help reduce the performance hit you are experiencing?
    The largest 3D file I've worked with was 38MB. My specs don't match yours (obviously) yet I managed to use 3D Orbit with no lagging.
  1. Constrained Orbit/Free Orbit problem
    By Buzzy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Jan 2012, 02:44 am
  2. AutoCAD 2012 and AutoCAD LT 2012 Service Pack 1 Released
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 7th Sep 2011, 01:34 am
  3. Replies: 0
    Last Post: 1st Sep 2011, 04:20 am
  4. Replies: 0
    Last Post: 13th Aug 2011, 01:30 am
  5. Autocad crashes on 3d orbit
    By RAO HASSAN in forum AutoCAD 3D Modelling & Rendering
    Last Post: 14th Dec 2009, 12:06 pm
Tags for this Thread
