Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: Dual Monitors?
  1. #11
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,134
    I have used dual in the past. As per JD's post, biggest advantage is being able to display Word, Excel, Outlook Documents or CADTutor solution ...etc and so forth, on one screen and working in CAD on the other.
    I use a single monitor now and just print the documents or switch windows.
  2. #12
    Forum Deity Jack_O'neill's Avatar
    Jack_O'neill's Computer Details
    xp
    Architectural
    Jack_O'neill's Discipline Details
    Architectural
    The bulk of my business is commercial curtainwall, site plans and floor plans. I do occasionally get a bit of tool and die, and the odd house now and again.
    AutoCAD 2010
    Sep 2008
    lost in the Arkansas wilderness
    2,146
    Quote Originally Posted by SLW210 View Post
    One of mine died so I thought I'd just go back to a single for a while....just about drove me to drinkin...did that for about a week and that was enough. Second monitor was replaced. It annoys me when I'm out on the road with this laptop to only have one monitor and I don't even use it all that much.
    Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
  3. #13
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    I think Jack's post #4 is the best example where you have reference material up on one monitor while working with ACAD in the other. From reading recent study's it sounds like one large monitor is better than two,and it makes sense to me having worked with two 24" for a while.
    If you read other study's they also find that the distraction of two monitors can also hurt productivity. The reasoning is if you have your email up on one screen (as an example) and ACAD on the other you will be tempted to stop and read your email as those come in. So anything on the other screen becomes a distraction and makes it harder to focus and stay on task.
    I like two monitors and would hate to go back to one unless it was one very large one, 27" or larger.
    My previous two monitors were 21" and were made so you could rotate them 90 degrees, so the one where I was working on Word I had in portrait mode and the ACAD one was in landscape. That worked real well for that scenario. When I needed a spread sheet (or MS Project file), etc, up on screen I could rotate back to landscape and change it quickly in the software to display properly. Surfing on the internet works better in portrait mode as well, at least for me.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  4. #14
    Full Member
    Bartjacks's Computer Details
    Windows 7
    Dell m2200
    intel I7
    16g
    NVIDIA 2gb
    Electrical
    Bartjacks's Discipline Details
    CADD/ BIM Operations
    Electrical
    MEP 2013
    Apr 2012
    Denver, Co
    31
    I didnt even realize you could do CAD on 1 Monitor. i'm a minimum of Two monitors at all times, i have three while at work cuz i use my laptop as one. i cant even imagine doing it on one moniter anymore. i always have the main drawing area on one, then my tool palettes, quick prop, layer and xref managers up on the second. i usually use the third for windows explorer and such (much like JD Mathers). when i'm really going to town, my project manager box is on the third screen along with Navis for quick coordination on the MEP side, or client documents for the 2d stuff. so all sarcasm aside, i thoroughly recommend the second monitor. you can NEVER have to much Drawing real state when it comes to cad
  5. #15
    Senior Member
    Raudel Solis's Computer Details
    Windows 7
    Hp dv7 4073nr
    Core i7 720 Qm
    6gb Ram 2/6
    1Gb Ati 5650
    500 Gb internal Hd
    500 Gb External Hd
    Built in & 32" External Hd Monitor
    Architectural
    3ds Max 2013
    Nov 2010
    Arlington Texas
    453
    Quote Originally Posted by Bartjacks View Post
    oh yes, more monitors = better workflow..
    you just need to get accustomed to the new setup..
    all major graphics manufacturers offer a control panel to setup your monitors to display the way you want them..
    windows offers the basic.. Duplicate, external only, extend.. etc.
    but yes.. the main reason to get more monitors is to optimize workflow..
    no more switching and sending windows front to back, everything you need to do is on it's own monitor depending on how many you have....
    When all else fails..... CTRL+A, DEL, CTRL+S
  6. #16
    Forum Newbie
    AutoCAD LT 2012
    May 2012
    8
    I think everything has already been said about it by now, but I would say:
    Advantage: you work more digitally, you don't have to print a pdf with important information for your work, but just put it in the second screen.
    Disadvantage: two screens distract your focus. Youtube on the second screen is great fun, but when you don't finnish your work before noon, it isn't that funny anymore!
  1. Screen Shots on Dual Monitors - FYI
    By Bmapper in forum CAD Management
    Last Post: 14th Jul 2010, 04:30 pm
  2. config dual monitors
    By onkelbob in forum AutoCAD Beginners' Area
    Last Post: 3rd Apr 2010, 03:44 am
  3. Isolate toolbars to one of dual monitors
    By qball in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Mar 2010, 11:34 pm
  4. Update Xref notifications - Dual monitors
    By Trebuchet in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 12th May 2009, 01:41 pm
  5. AutoCad and Dual Monitors
    By neilma in forum Hardware & Operating Systems
    Last Post: 14th May 2004, 10:37 pm
