+ Reply to Thread
Results 1 to 10 of 10
Thread: align_text
  1. #1
    Junior Member
    Discipline
    P&ID
    bwdeen's Discipline Details
    Occupation
    Designer
    Discipline
    P&ID
    Using
    AutoCAD 2010
    Join Date
    Feb 2012
    Location
    Midwest
    Posts
    10
    Wink align_text
    As this has probably been discussed before, I'm stuck and pulling my hair out...lol
    the text on the right is middle-align, prefect, the text on the left is also middle-aligned but is offset. How can i fix the left text to match the right?
    Thanks,
    BW Deen
  2. #2
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,178
    Default
    Use MATCHPROPERTIES enter 'MATCHPROP' at your commandline, then just follow the prompts, should fix you right up. Or you can find it on your MODIFY dropdown from the menu bar.
    Volume and repetition do not validate opinions forged in the absence of thought.
  3. #3
    Junior Member
    Discipline
    P&ID
    Occupation
    Designer
    Discipline
    P&ID
    Using
    AutoCAD 2010
    Join Date
    Feb 2012
    Location
    Midwest
    Posts
    10
    Default
    Thanks for the reply:
    I have tried MATCHPROPERTIES but its doesn't fix the "spacing" issues that appears on the left text.....just odd setting somewhere and i cant remember where....
  4. #4
    Senior Member Squirltech's Avatar
    Computer Details
    Squirltech's Computer Details
    Operating System:
    Windows 7 Enterprise, Service Pack 1
    Computer:
    @xi
    RAM:
    32.0 GB
    Primary Storage:
    230 GB
    Monitor:
    Dual Dell 21"
    Discipline
    Surveying
    Squirltech's Discipline Details
    Occupation
    Senior Survey Technician
    Discipline
    Surveying
    Using
    Civil 3D 2012
    Join Date
    Oct 2010
    Location
    30 15' N, 97 44' W
    Posts
    166
    Default
    Have you tried to "remove formatting" on the text on the left? Highlight the text in the edit box. Right click and select "remove ALL formatting". Just a shot in the dark. Hope it works.
    T. Nelson
    Sr. Survey Technician
    http://www.saminc.biz
    "The only thing left to do is EVERYTHING!" - Jesse James
  5. #5
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,178
    Default
    Are those text, they look like MTEXT. Do you have column values applied to the on on the left, causing it to leave a margin perhaps?
  6. #6
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,178
    Default
    Good thought, that will probably take care of it.
  7. #7
    Junior Member
    Discipline
    P&ID
    Occupation
    Designer
    Discipline
    P&ID
    Using
    AutoCAD 2010
    Join Date
    Feb 2012
    Location
    Midwest
    Posts
    10
    Default
    ugh, are you as puzzled as I am....just removed the columns and formatting, still same.
  8. #8
    Junior Member
    Discipline
    P&ID
    Occupation
    Designer
    Discipline
    P&ID
    Using
    AutoCAD 2010
    Join Date
    Feb 2012
    Location
    Midwest
    Posts
    10
    Default
    whoa, line space style and height were slightly off....i found it of course by highlighting both items and reviewing the properties.....Thanks all for helping....
  9. #9
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,178
    Default
    All's well that ends well, glad you figured it out!
  10. #10
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,178
    Default
    As is so often the case, when you get stuck, turn to somebody smarter than the average bear.
    http://www.lee-mac.com/matchtextprops.html I've never used it, but as a student of history, I would be surprised if it didn't.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
