Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
  1. #11
    AutoCAD 2013
    Nov 2011
    5,976
    It makes me nuts when I am working on a drawing which was created on an Imperial template, because all of the scale references and lists show default Imperial units of measure, even if the UNITS are set correctly. If you check in OPTIONS > USER PREFERENCES > DEFAULT SCALE LISTS it is very easy to determine what sort of template was used. That of course is much more difficult than just referencing any of the scale lists, which will display architectural scales. As a carpenter trained in the states, I am fine doing woodwork with Imperial measurements, I just don't want to have to use them and think that hard, unless I need to in Autocad.
  2. #12
    Forum Newbie
    AutoCAD 2010
    Feb 2011
    1
    Hi there's another way also, type STARTUP command and change the value from 0 to 1 and save.so that eveytime you open a new drawing, the startup dialog box will appear and you can choose your drawing whether imperial or metric....hope it can help...
    regards,
    sotelliza
  1. Dimension Parameter units
    By LaneClare in forum AutoCAD Drawing Management & Output
    Last Post: 28th Mar 2012, 02:17 pm
  2. Dimension units change after saving
    By davidad in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Feb 2012, 08:55 pm
  3. Dimension Units
    By ryank7 in forum AutoCAD Beginners' Area
    Last Post: 27th Sep 2011, 01:07 pm
  4. dimension & units
    By 19cruthik68 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Sep 2011, 04:40 pm
  5. Dimension Architectural Units
    By Brunello19 in forum AutoCAD Drawing Management & Output
    Last Post: 17th May 2005, 02:28 pm
Tags for this Thread
