Results 1 to 3 of 3
    Full Member
    Inventor 2011
    Apr 2012
    27
    Default Choosing a Sketch Plane
    Another question re: Inventor 2011
    I've attached a part file-- a simple cylinder. I am trying to use one end of the cylinder (the end without the external threads) as a sketch plane upon which I create a new 2D sketch. Inventor does not allow me to select this face as a sketch plane...
    Question is: Why not?
    I understand that I can get around this by creating a work plane on this face.
    But why can't I use the face directly as a sketch plane?
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    It is not planar. The original sketch is garbage at a slight angle to horizontal and vertical. Where did you get this sketch geometry? AutoCAD?
    The revolve results in conic faces since the line that creates that face isn't perpendicular the axis of revolution.
    I recommend you read this document http://home.pct.edu/~jmather/skillsusa%20university.pdf
    I recommend you dimension your sketches - in which case the problem becomes rather obvious.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Full Member
    dshowalt's Computer Details
    Windows 7 64-bit
    Intel i7
    8GB
    Nvidia
    Education
    dshowalt's Discipline Details
    Education
    Education
    Inventor 2012
    Dec 2009
    Kansas City, USA
    57
    As JD would say your sketch is way too complicated with much line segments. And not comstrained fully. Simplify the sketch geometry and fully constrain the sketch.
    OOPS JD beat me to it
  1. angled sketch plane
    By pete1968 in forum Autodesk Inventor
    Last Post: 28th Mar 2012, 09:02 pm
  2. How do I rotate a sketch to another plane?
    By cvriv.charles in forum Autodesk Inventor
    Last Post: 2nd Aug 2011, 08:29 am
  3. Plane and sketch visibility
    By Hawk646 in forum Autodesk Inventor
    Last Post: 17th Dec 2010, 02:24 pm
  4. reassign sketch plane - body disappear
    By jkristia in forum SolidWorks
    Last Post: 24th Dec 2008, 01:59 am
  5. Changing sketch plane
    By Brian in forum Autodesk Inventor
    Last Post: 11th Dec 2007, 06:25 pm
