DRBJR45 Posted April 19, 2012 Share Posted April 19, 2012 Jd, bishop, here is the file. Any and all comments greatly appreciated. So, i need to divide this part into several sections. All equal in height. Then project onto each level (plane) the profile that is created when you use "project cut edges"....and from that profile, which needs to be editable, add flanges and seams that run up and down the sections. ......also, i started the real project as an assembly, but i had problems uploading the assembly...only parts will upload..?? Thanks. PHILLY BY DON.ipt Quote Link to comment Share on other sites More sharing options...
