Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Full Member
    AutoCAD 2009
    Aug 2011
    45
    Default Need Lisp : create rectangle between rectangle
    Need lisp for create rectangle (red colour) between rectangle (black colour)
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,951
    Consider the Offset, and the Trim & Pedit, or the Pedit Commands.
    "Potential has a shelf life." - Margaret Atwood
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,791
    Another way with lisp pick two diag corners xoff yoff can be different draws new rectang. 3pt answer if rectang on angle.
    I would go 3pt you can bet if you make it square only you need an angle version.
    Senior Member ketxu's Avatar
    ketxu's Computer Details
    Sorry, my English not well :(
    AutoCAD 2007
    Sep 2010
    169
    Git_thailand, please re-read all off topic that you have posted. Please give more detail for what you want.
  5. #5
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,106
    Quote Originally Posted by git_thailand View Post
    Looks easy enough. The only existing entiy is the black pline? and youre wanting to create 5 more? or just 4 not including the inner rectangle?
  6. #6
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,631
    Quote Originally Posted by pBe View Post
    I guess there are only two , aren't they ?
    - When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
  7. #7
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,106
    Quote Originally Posted by Tharwat View Post
    Oh yeah. ... but it could also be four depending on how you see it. 5 even if you include the middle one as a separate entity.
    Oh well....
    Code:
    (defun c:BeatBox (/ _HiLow _Box _trans rec pts low high)
      (defun _HiLow (lev lst)
        (list
          (apply lev (mapcar 'car lst))
          (apply lev (mapcar 'cadr lst))
      (defun _Box (p1 p2)
        (command "_rectang" "_non" p1 "_non" p2)
      (setq _trans (lambda (pt) (trans pt 0 1)))
      (if (and
        (setq dist (cond
                        (   (getdist
                                (strcat "\nOffset Distance"
                                    (if dist (strcat " <" (rtos dist) ">: ") ": ")
                        (   dist   )
        (setq rec (ssget
           '((0 . "LWPOLYLINE") (-4 . "&=") (70 . 1))
        (repeat  (setq i (sslength rec))
        (setq pts (mapcar 'cdr
            (vl-remove-if-not
              '(lambda (j)
          (= (car j) 10)
              (entget (setq e (ssname rec (setq i (1- i)))))
       pts (mapcar '_trans pts)
        (setq Low  (_HiLow 'min pts)
       High (_HiLow 'max pts)
      (_Box (list (car low) (+ (cadr low) dist))
            (list (car high) (- (cadr high) dist))
      (_Box (list (+ (car low) dist) (cadr low))
            (list (- (car high) dist) (cadr high))
    HTH
    UPDATED:
    Last edited by pBe; 20th Apr 2012 at 01:51 pm. Reason: Updated for Multiple objects
  8. #8
    Full Member
    AutoCAD 2009
    Aug 2011
    45
    create rectangle between two rectangle
  9. #9
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,138
    You really need a lisp routine to do this? Really??
  10. #10
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,106
    Geez. I was right the first time. It is indeed 4.
    But then again...
    I am wondering myself.
  1. LISP for a rectangle inside a rectangle
    By Grigs in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Mar 2012, 07:11 pm
  2. select block or rectangle to create namedview
    By pmxcad in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Feb 2012, 07:35 pm
  3. Lisp for rectangle
    By RRS1987 in forum AutoLISP, Visual LISP & DCL
    Last Post: 27th Oct 2011, 02:23 pm
  4. Replies: 2
    Last Post: 4th Oct 2010, 12:16 pm
  5. Create a Rectangle around Text
    By Zeusovsky in forum .NET, ObjectARX & VBA
    Last Post: 17th Aug 2010, 09:37 am
