Page 1 of 2 1 2 LastLast
Results 1 to 10 of 16
    Forum Newbie
    Arg777's Computer Details
    Windows 7
    HP
    Architecture 2012
    Apr 2012
    5
    Default Help with figuring out how to model this structure
    Hi everyone, Im an architecture student and have some experience with modeling in 3d AutoCad and very minimal experience with revit and 3ds max. I need to model this structure and I'm having a tough time trying to figure out how to go about doing that.
    It is supposed to be an outdoors performance space that is covered by this shell like structure. It's composed of concrete ribs meeting at a point but only in a semicircular shape. The webbing inbetween the ribs have catenary curved arched openings with some of those openings having a lattice structure inside. The top of this hemispheric dome is supposed to be a sort of skylight with mullion work and glass. Here are some sketches of what I had in mind:
    Now I started to model it in 3D Cad since that's what I know best but this is a very complicated curved structure where curves dont just happen on one axis but 2 or 3. I was able to somewhat create the ribs but i have no clue how to actually create the shell webbing in between and then cut out the catenary curved arches with lattice work or the skylight component for that matter.
    If anyone could help me out on this i'd really appreciate it! If it is easier to do in 3ds max, then I am able to do that too, but I just need some guidance. I've attatched my attempt of this model with the corresponding floorplan.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    The skylight could be created by slicing the ribs and webbing using an extruded arc. The SLICE command utilizing the SURFACE option would do the trick.
    As for creating the "lattice work" affect I imagine you would have to create the required profiles, locate them properly (i.e.-relative to the curved webs), extrude them through the webs, then do a subtraction.
    That's how I view it. If you are patient I am sure other forum members, more knowledgeable than myself, will post alternate suggestions.
    Forum Newbie
    Windows 7
    HP
    Architecture 2012
    Apr 2012
    5
    Thanks ill try those but I still need some more help with this. Especially the webbing because no matter how i do it, it doesn't seem to fill the space in between the ribs, either it leaves a gap or it just overshoots them completely. Anyone else have suggestions?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    I thought you already created the webbing and just had to trim it to fit.
  5. #5
    Full Member
    Landscape
    3D generator's Discipline Details
    generative design consultant
    Landscape
    Extensive experience in sitework detailing using AutoCAD 3d models as the basis for 2d construction documentation. I've been 3d modeling in AutoCAD since the late 90's. Currently transitioning to Inventor.
    Inventor 2012
    Jan 2011
    San Antonio, Texas USA
    44
    Idea I'd Use Rhino
    Catenary curves have the unique property that when suspended they are in perfect tension and when they are flipped to create an arch they are in perfect compression. This means the arch is totally self supporting just by virtue of its geometry. Gaudi was a big fan of this form finding technique.
    True catenary (also called funicular) modeling is very challenging to achieve because it deals with the force of gravity on the geometry you’re creating. This requires a live physics engine as well as a geometry kernel working together to create the catenary curves.
    Catenary curves can be approximated by parabolic curves but the results will not have the same structural properties.
    http://mathforum.org/library/drmath/view/65729.html
    This could all be boiled down to the math in a .NET script that you can run inside AutoCAD, but I doubt the results would be very interactive or intuitive. Besides, I wouldn’t have a clue how to do that anyway!
    http://through-the-interface.typepad...using-net.html
    Your best bet is probably using Rhino with the free plug-ins Grasshopper and Kangaroo. Here’s a video illustrating how this modeling technique would work: http://www.grasshopper3d.com/video/k...atenary-system
  6. #6
    Forum Newbie
    Windows 7
    HP
    Architecture 2012
    Apr 2012
    5
    Thanks for the reply but that is all far to complicated for what I am trying to do. I don't need to have the accurate forces or know the physics of it, this is just supposed to be more of a conceptual model if anything. Gaudi is where I get the idea to use the catenary curves and i was able to use a plugin to form them in 2D so although they may not be "true catenaries" they are close enough for what I am trying to do.
    As for using rhino, I've never used that program and don't have the time to learn it so I would prefer if the solutions stayed within the bounds of AutoCad or 3ds Max.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Post what you have accomplished since 19 April. We'd like to see the extent of your progress. Thanks.
  8. #8
    Super Moderator Strix's Avatar
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    I'm intrigued
    What are the 'walls' made of? or is it a skylight and webbings with nothing inbetween?
    Is this the effect you were aiming for?
    Find your new best friend at Rain Rescue
    If you are a good drafter, tech will help. If you are a bad drafter, nothing will help. - Jack_O'neill at CADTutor
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    The structure is made of concrete.
  10. #10
    not applicable
    Nov 2005
    Sheffield UK
    3,081
    Quote Originally Posted by Arg777 View Post
    Nope - still can't find where the material between the concrete ribs is defined (other than the top of the dome being glass)... have you two had off-forum conversation about this?
  1. Replies: 6
    Last Post: 8th Feb 2012, 04:03 pm
  2. Having Trouble Figuring Out How to Draw SW Ash Creek Drive
    By Megaforce1 in forum Student Project Questions
    Last Post: 10th Aug 2011, 05:55 pm
  3. Figuring out angles
    By Anna_here in forum AutoCAD Beginners' Area
    Last Post: 1st Aug 2006, 03:09 pm
  4. Can Someone Test My 3D Play Area Structure AutoCAD Model?
    By woodward007 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Apr 2006, 12:10 am
  5. Figuring out area for imported dxf line drawings
    By JG0000000000 in forum AutoCAD General
    Last Post: 13th Sep 2005, 03:50 am
Tags for this Thread
