+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    Feb 2012
    Posts
    19
    Default How do I complete this? (2)
    Hello, it's me again
    I'm having another little problem.
    How do I complete this line? I tried doing it with the ellips tool but that didn't seem to work.
    Thanks in advance,
    Mike
  2. #2
    Forum Deity MSasu's Avatar
    Discipline
    Construction
    MSasu's Discipline Details
    Occupation
    engineer
    Discipline
    Construction
    Details
    AutoLISP programmer
    Using
    AutoCAD 2013
    Join Date
    Mar 2009
    Location
    Brasov, Romania
    Posts
    2,997
    Default
    The screen shot is what you have drawn so far? Are you looking to draw a line between those red points? Is the outside shape an ellipse or a circle?
    If the above are correct, then: to locate the top point use either Intersect or Quadrant Osnap mode; for bottom one End mode.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  3. #3
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    Feb 2012
    Posts
    19
    Default
    it need to be something like this:
    Everything that you see are circles, except the line i'm searching. It needs to be a trimmed elliptical line or something.
  4. #4
    Discipline
    Construction
    Occupation
    engineer
    Discipline
    Construction
    Details
    AutoLISP programmer
    Using
    AutoCAD 2013
    Join Date
    Mar 2009
    Location
    Brasov, Romania
    Posts
    2,997
    Default
    Don’t you have an imposed geometry for that part? Is this an exercise that you have to complete or you are just playing with AutoCAD?
    You can draw a curve there by either using (1) the ELLIPSE command and indicating the points in the order noted below, use TRIM to remove un-wanted parts or (1) by an arc with first end in point 1, middle point in an arbitrary location and finished in point 2.
    Regards,
    Mircea
  5. #5
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,039
    Default
    You could try the CIRCLE command with the Tan-Tan-Radius option and trim away what you don't need.
  6. #6
    Super Member SEANT's Avatar
    Using
    AutoCAD 2012
    Join Date
    Aug 2005
    Location
    Rhode Island
    Posts
    1,968
    Default
    Several entity types could be made to intersect those points. If tangency was required at all three, though, then the simplest would be a hyperbolic arc. The arc attached was drawn as a Degree 2 spline.
  7. #7
    Junior Member
    Using
    AutoCAD 2009
    Join Date
    Feb 2012
    Posts
    19
    Default
    The spline it is
    Thanks seant, you did it again.
Similar Threads
  1. How do I complete this?
    By Mike G in forum AutoCAD Beginners' Area
    Last Post: 8th Apr 2012, 05:09 pm
  2. Help for a complete newbie
    By smp3728 in forum MEP
    Last Post: 12th Dec 2009, 12:31 am
  3. Vla- Complete listing
    By ollie in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jul 2009, 04:07 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
