Results 1 to 5 of 5
    Forum Newbie
    MEP 2012
    Nov 2011
    3
    Default Learning Cadd MEP
    Just Got started with MEP. Have been working with AutoCadd for years. Can't seem to change the units from Metric to Architectural. Am I stuck with Metric or how can I change it?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    Menu: Application menu Drawing Utilities Units
    Does this work for you?
    Forum Newbie
    MEP 2012
    Nov 2011
    3
    Default Cadd MEP
    Seems I thought I could set the units without openning a file. When opening an existing file the units have been pre-set. While somewhat different then Cadd 2010 it works. It will take some time and a little help to get comfortable with MEP.
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,483
    Set your STARTUP to 1 if you want the wizard every time you start AutoCAD MEP. Or just type UNITS and make your adjustments, it's the same thing. Best thing to do is set your default Template with all these settings so you don't always have to do this every time.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  5. #5
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,131
    A template contains presets for either METRIC or IMPERIAL, make sure that you are starting with an appropriate template. You can still make changes to UNITS once a dwg is opened, but you cannot change that default type which is inherent to the template from within a DWG. Your PROPERTIES scale values will indicate architecturally, or metrically based upon the template used. You probably want to specify an appropriate QNEW template to ensure that you always have the dimensional format which you favor. You might also want to SYSVDLG > STARTUP and explore the various VARIABLE driven startup options.
  1. cadd project
    By midnightb3ast in forum AutoCAD Beginners' Area
    Last Post: 30th Dec 2011, 09:05 am
  2. code deletion on CADD
    By mafioso in forum AutoCAD General
    Last Post: 22nd Oct 2008, 02:16 am
