Results 1 to 3 of 3
    Junior Member
    AutoCAD 2013
    Apr 2012
    10
    Exclamation logo. not sent with e-transmit
    i copy past the jpg in the model space and then modified it to fit in my frame.
    i sent an e-transmit of my drawing but the logo didn't stick to it.
    i was told to attach... should i modify the logo in Photoshop and then attach it as an xref ant then use e-transmit?
    i have 2013 and the client has 2007 . (just in case it mattered)
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,207
    If you paste an image into your drawing, it becomes part of the drawing. eTransmit doesn't include it as a file because it's not a separate file. Check your output.
    breaking AutoCAD on a regular basis since 1991
    Junior Member
    AutoCAD 2013
    Apr 2012
    10
    what do you mean by output?
    I was suggested to insert it as an x ref.
    So if i insert my logo in my frame that is one drawing. i would have then to insert my frame as an xref in my principal drawing ? Or insert my frame like a did, as a block, with attribute text and then after insert my logo as an xref.
    but in both ways i would have to modify my logo first instead of modifying it in the drawing?.... I'm really confuse of how i should do this.
    For the e-transmit to work everything has to be in the same file as the principal drawing. the frame and the logo.
  1. E-transmit
    By mggeray in forum AutoCAD Beginners' Area
    Last Post: 24th Nov 2010, 08:17 am
  2. e-transmit
    By jaypro in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Apr 2010, 09:46 am
  3. e-Transmit
    By Rhayes in forum AutoCAD General
    Last Post: 26th Jun 2008, 10:15 pm
  4. E Transmit
    By happyunited in forum AutoCAD Drawing Management & Output
    Last Post: 1st Jun 2007, 02:31 pm
  5. E-Transmit and X-Clip
    By brownpj in forum AutoCAD Drawing Management & Output
    Last Post: 16th Nov 2005, 07:28 pm
