+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: Completely lost
  1. #1
    Junior Member
    Computer Details
    Quick Karl's Computer Details
    Operating System:
    Win 7 64-bit
    Computer:
    Custom built
    Motherboard:
    ASUS Sabertooth X58
    CPU:
    i7-980 3.33 GHz 6-core
    RAM:
    24GB
    Graphics:
    ATI V7800 2GB
    Primary Storage:
    WD 300GB RAPTOR SATA 10K
    Monitor:
    HP ZR24w
    Discipline
    Multi-disciplinary
    Quick Karl's Discipline Details
    Discipline
    Multi-disciplinary
    Details
    After a 20+ year career in architecture I am back in school for an engineering degree.
    Using
    Architecture 2012
    Join Date
    Apr 2012
    Location
    Scottsdale, AZ USA
    Posts
    15
    Default Completely lost
    Ok this is going to be tricky
    First, the only thing I know about LISP and VLISP, is that when they work, they’re great!
    In 2004 a friend wrote a group of lisp routines that I rely on heavily, and although I was somehow able to get them to work on my new ACAD2012 Win7 64-bit computer, I can NOT, for the life of me, figure out what I did to get them to work. It had something to do with adding _$ (vl-load-com) somewhere, and then suddenly everything worked, but I haven’t a fricken clue what I did or where I did it. There IS a vlx folder in the directory where all this stuff is installed, and it has vlx stuff in it.
    Having experienced an annoying memory glitch I just had to reload everything on my computer and, I have the menus loaded (menuload), and can see the toolbars that are part of the lisp tools, and even one of them actually works (changes the drawing scale (and dim scale concurrently) and LT scale to what I like from a list), but other tools like a dimension tool that automatically places dimensions on the DIM layer and at the proper dimscale for the drawingscale, regardless of what layer is current, and all the other tools, just report something like this:
    Code:
    Command: (setq DIMCMND
    "_dimlinear")"_dimlinear"
    Command: dimlyr undo Current settings:
    Auto = On, Control = All, Combine = No,
    Layer = No
    Enter the number of operations to undo or
    [Auto/Control/BEgin/End/Mark/Back]
    <1>: begin
    Command: bad argument type: FILE
    nil
    Like I said, I did something with a _$ (vl-load-com) somewhere that made all of these tools work, but I am getting old and just can’t remember what the * I did.
    If anyone can help I can’t begin to tell you how thankful Iwould be. It worked only a week ago before I had to reinstall everything, and I am miffed...
    Thank you
  2. #2
    Forum Deity MSasu's Avatar
    Discipline
    Construction
    MSasu's Discipline Details
    Occupation
    engineer
    Discipline
    Construction
    Details
    AutoLISP programmer
    Using
    AutoCAD 2013
    Join Date
    Mar 2009
    Location
    Brasov, Romania
    Posts
    3,000
    Default
    Just create a text file named acaddoc.lsp in your profile's Support folder (check in Properties -> Files --> Support File Search Path) and paste the line below in that file. This will ensure that VisualLISP extension is loaded in every drawing.
    Code:
    (vl-load-com)
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  3. #3
    Senior Member marko_ribar's Avatar
    Computer Details
    marko_ribar's Computer Details
    Operating System:
    Windows 7 Ultimate X64
    Computer:
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    Motherboard:
    INTEL compatibile
    CPU:
    quad core 4x2.66GHz
    RAM:
    8GB
    Graphics:
    NVIDIA GeForce 6600 GT
    Primary Storage:
    250 GB
    Secondary Storage:
    500 GB
    Monitor:
    Samsung 17''
    Discipline
    Architectural
    marko_ribar's Discipline Details
    Occupation
    Architecture, project designer, project visualisation
    Discipline
    Architectural
    Details
    space design - modeling and animations
    Using
    AutoCAD 2012
    Join Date
    Feb 2010
    Location
    Belgrade, Serbia, Europe
    Posts
    331
    Default
    Try to create acaddoc.lsp file and place it in AutoCAD Support folder... Inside acaddoc.lsp add line (vl-load-com), and whenever you start CAD (vl-load-com) will be automatically loaded into memory... This is probably the reason why programmers of routines have omitted (vl-load-com) line within their codes - they simply had that function reactors for making operational all vla- VisualLisp AciveX COM+ functions loaded in the start so they don't concentrate of making functions operational, but they just write them like they are built-in AutoLisp Vanilla API...
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  4. #4
    Junior Member
    Computer Details
    Operating System:
    Win 7 64-bit
    Computer:
    Custom built
    Motherboard:
    ASUS Sabertooth X58
    CPU:
    RAM:
    24GB
    Graphics:
    ATI V7800 2GB
    Primary Storage:
    Monitor:
    HP ZR24w
    Discipline
    Multi-disciplinary
    Discipline
    Multi-disciplinary
    Details
    Using
    Architecture 2012
    Join Date
    Apr 2012
    Location
    Scottsdale, AZ USA
    Posts
    15
    Default
    I've tried that in both the acad2012doc.lsp AND the acad2012.lsp files (they are the only files like this I could find on my system) - and I have the correct support file path - but still the same error... should I NOT be using these '2012' version of this file (should I just create a acaddoc.lsp file)??
  5. #5
    Discipline
    Construction
    Occupation
    engineer
    Discipline
    Construction
    Details
    AutoLISP programmer
    Using
    AutoCAD 2013
    Join Date
    Mar 2009
    Location
    Brasov, Romania
    Posts
    3,000
    Default
    Please do not modify those file - are reserved for AutoCAD. Create your user auto-loader as instructed above.
    If you don't have an acaddoc.lsp file on your system, then create a new one using Notepad; if there is one then open it and append at the end.
    If by doing so your tools still not work, then you should revise their installation/setup procedure.
    Regards,
    Mircea
  6. #6
    Junior Member
    Computer Details
    Operating System:
    Win 7 64-bit
    Computer:
    Custom built
    Motherboard:
    ASUS Sabertooth X58
    CPU:
    RAM:
    24GB
    Graphics:
    ATI V7800 2GB
    Primary Storage:
    Monitor:
    HP ZR24w
    Discipline
    Multi-disciplinary
    Discipline
    Multi-disciplinary
    Details
    Using
    Architecture 2012
    Join Date
    Apr 2012
    Location
    Scottsdale, AZ USA
    Posts
    15
    Default
    Quote Originally Posted by MSasu View Post
    No idea what you mean revise installation/setup procedure...
    I restored the original 2012 files and created the new file with only (vl-load-com) and saved it to the profile's support location - still the same error
    I could swear that the first time I had to go through this I used this exactly _$ (vl-load-com) including the underscore and dollar sign, but I wish I could remember what the heck I did??? Would that be something inside a lisp program??? Should I add the _$ in front of (vl-load-com) in my new acaddoc.lsp?
    I guess I should have been smart and wrote down that the heck I did -- I hate working wothout these lisp tools :-(
  7. #7
    Discipline
    Construction
    Occupation
    engineer
    Discipline
    Construction
    Details
    AutoLISP programmer
    Using
    AutoCAD 2013
    Join Date
    Mar 2009
    Location
    Brasov, Romania
    Posts
    3,000
    Default
    The "_$" is the prompter of VisualLISP editor console; I'm not aware to be used somewhere else. You can load there the VL extension and will look like you wrote it, but then will have to do so in each and every drawing.
    By "installation/setup procedure" I mean the exact procedure you should follow to get the said tools pack installed in your AutoCAD. It doesn't come with a written document describing the step-by-step setup? Can you contact the developer? Maybe you are missing a setup step - for example to add a folder to Support File Search Path list (from the error you posted above seems that a routine isn't able to locate a file).
    Regards,
    Mircea
  8. #8
    Junior Member
    Computer Details
    Operating System:
    Win 7 64-bit
    Computer:
    Custom built
    Motherboard:
    ASUS Sabertooth X58
    CPU:
    RAM:
    24GB
    Graphics:
    ATI V7800 2GB
    Primary Storage:
    Monitor:
    HP ZR24w
    Discipline
    Multi-disciplinary
    Discipline
    Multi-disciplinary
    Details
    Using
    Architecture 2012
    Join Date
    Apr 2012
    Location
    Scottsdale, AZ USA
    Posts
    15
    Default
    The person that wrote these isn't around anymore, and he was very hard to work with.
    I've installed this many times, it still works perfect on a 32bit laptop with XP Pro on it -- I actually had it working on this 64bit Win 7 computer before I had to reload everything. I was searching all over the internet for vl-load-something and somehow I got it to work but not this time... pain in my butt I swear.
  9. #9
    Discipline
    Construction
    Occupation
    engineer
    Discipline
    Construction
    Details
    AutoLISP programmer
    Using
    AutoCAD 2013
    Join Date
    Mar 2009
    Location
    Brasov, Romania
    Posts
    3,000
    Default
    Please try to paste the line below on AutoCAD's command prompt and press <Enter>. If will print "Is loaded!" then the VL extension is available. Other will get and error message (; error: no function definition: VL-STRING-SUBST).
    Code:
    (vl-string-subst "loaded" "*" "Is *!")
    Regards,
    Mircea
  10. #10
    Quantum Mechanic Lee Mac's Avatar
    Computer Details
    Lee Mac's Computer Details
    Operating System:
    Windows 7 Ultimate (32-bit)
    Discipline
    Multi-disciplinary
    Lee Mac's Discipline Details
    Discipline
    Multi-disciplinary
    Details
    Custom Programming / Software Customisation
    Using
    AutoCAD 2013
    Join Date
    Aug 2008
    Location
    London, England
    Posts
    15,732
    Default
    Hi Quick Karl,
    To clarify a few things from my perspective:
    1. Loading the Visual LISP Functions
    Before you can use any functions with the prefix: vla-* / vlr-* / vlax-* you will need to load the Visual LISP Module; this module only needs to be loaded once per session.
    To ensure the Visual LISP module is loaded , create a file in an AutoCAD Support Path called ACADDOC.lsp (notACAD2012DOC.lsp or ACAD2012.lsp, as these are reserved for use by the application and will be overwritten if you upgrade or update the software).
    Before creating this file, first search your AutoCAD Support Paths to ensure that the file doesn't already exist. If the file already exists, in the following steps, modify the existing file.
    If the file doesn't already exist, open Notepad and type the following:
    Code:
    (vl-load-com)
    Now save this file as ACADDOC.lsp (with the 'Save As Type' box set to 'All Files').
    Note: you only need to type (vl-load-com) not _$ (vl-load-com). The "_$" is the Visual LISP IDE Console Prompt.
    2. Your Applications
    From the message you are reporting:
    Code:
    Command: (setq DIMCMND "_dimlinear")"_dimlinear"
    Command: dimlyr undo Current settings: Auto = On, Control = All, Combine = No,
    Layer = No
    Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back]
    <1>: begin
    Command: bad argument type: FILE nil
    It would appear that your programs rely heavily on calling AutoCAD commands. This can be an unreliable approach, since the prompt order, behaviour and available options for many AutoCAD commands will vary across versions, resulting in many applications working in one version, but not another.
    The error:bad argument type: FILE nil would indicate that the program is supplying a function which requires a file descriptor parameter (such as write-line / write-char / princ / print / prin1) a null argument. However, this is almost impossible to debug without the ability the view the program source code.
    Lee Mac Programming
    With Mathematics there is the possibility of perfect rigour, so why settle for less?
    Just another Swamper
Similar Threads
  1. Completely lock a drawing.
    By boofredlay in forum AutoCAD Drawing Management & Output
    Last Post: 12th Apr 2007, 09:03 pm
  2. completely new
    By Precursor in forum AutoCAD Beginners' Area
    Last Post: 7th Dec 2005, 09:04 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
